Black Ur Project
  • K Simmonds
    • Dec 2007
    • 7627
    Looking great Dave, you really have done this car justice.
    I can't recall without going back to the start of the thread but what sort of condition is the interior in? UV light normally degrades the fabric quite badly however the car was garaged for 30 odd years so hopefully it's still good.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
      • Dec 2017
      • 5999
      The interior is quite good. A small hole in the drivers seat needs fixing. No UV damage.
      • K Simmonds
        • Dec 2007
        • 7627
        That's great news, so nothing a good upholster couldn't sort out.
        1994 MTM RS2.
        2000 B5 TQS.
        • Blagave
          • Aug 2023
          • 270
          Dave, I know the time you are putting in and you are doing a fantastic job.
          After seeing your prop shaft rebuild, I am very happy I found a new one
          • jbrentd
            • Dec 2009
            • 247
            Such great work! Although Spring brings lot of good things, it does tend to slow down progress in the shop.
            2001 A4 Avant QMS - FXK04'd
            1991 Audi CQ - Project
            1996 A4 12v Quattro Manual - SOLD
              • Dec 2017
              • 5999
              Today I fitted the front subframe.
              Verkline bushes going in.
              The gearbox was supported using the transmission jack so I could remove my home made support.
              I used the old marks to line everything up.
              Then the rest of the exhaust went on.
              It might need a little tweak as it's touching the floor above the rear diff.
              • Rikki Kitto
                • Feb 2010
                • 6276
                  • Dec 2017
                  • 5999
                  Peter Reeve at Quattro Corner kindly sent me a new circlip of the right dimensions free of charge.
                  You can see how mangled the old one was.
                  I wasted no time at all fitting it and it was quite a quick job.
                    • Dec 2017
                    • 5999
                    I've been busy doing logs and other such things so haven't spent much time on the Ur.
                    I did get the hoses all washed. They were disgusting inside.
                    And after soaking for several days in good penetrating oil, the slave cylinder pipe eventually shifted.
                    It looks ok but it's getting replaced while I have good access.
                    Spanner's in photo for reference.
                    19mm and 14mm.
                    Top nut on hard fitting is 12mm
                    • K Simmonds
                      • Dec 2007
                      • 7627
                      Good call replacing that manky looking 40 odd year old hydralic pipe whilst it's an easy job, it might be okay but for the sake of few quid it could save you a load of hassle down the line.
                      1994 MTM RS2.
                      2000 B5 TQS.
                        • Dec 2017
                        • 5999
                        Just ordered my custom slave flexi from HEL using their custom builder.
                        Under £30 delivered for a quality item is a bargain in my view.
                        Here is what you need if you want one.
                        Left fitting M12x1mm male swivel
                        Right fitting M12x1mm female swivel
                        Length 32cm
                        I've ordered black but you can choose your own colour.
                        Use the HEL car custom builder. The motorcycle builder is more expensive!
                        All fittings are stainless. Should last the life of the car.
                        • K Simmonds
                          • Dec 2007
                          • 7627
                          That's a great service and the price is excellent for a custom part, £30 well spent.
                          1994 MTM RS2.
                          2000 B5 TQS.
                            • Dec 2017
                            • 5999
                            Whilst waiting for the new slave pipe I fitted the front off side driveshaft and strut. A little thread lock here.
                            I also took my brake booster high pressure pipe to a local hydraulic place to get copied. It's been leaking and has made a right mess.
                              • Dec 2017
                              • 5999
                              And some of you who know me well will be wondering why I'm not replacing the slave
                              Well, I was told it was replaced when the clutch was done.
                              However, having looked at it, you won't be surprised to hear I ordered a new FTE one today.
                              Do it well, do it once
                                • Dec 2017
                                • 5999
                                I decided to make a start on the engine.
                                Apparently the cambelt was changed recently. It's interesting what I found.
                                I have an idler pulley and a 120 tooth belt. According to my chassis number I should have no idler and a 113 tooth belt.
                                I think it was common back in the day to upgrade to the newer version.
                                Now. More interesting.
                                After a lot of cleaning, I was able to get the bottom end in time.
                                Then it was interesting to find the top end was not!
                                So, whoever did the timing belt change didn't get it right. I can also see that someone used a screwdriver to lock the flywheel which isn't advisable and the crank bolt probably isn't as tight as it should be. So, I've ordered a new gates belt and happen to have an SKF water pump here and will do it again properly.
                                Under the rocker cover it's a bit grotty.
                                After a lot of cleaning, I'm getting there.
                                The turbo is good with no play.
                                It may have been replaced. Is this an 87 build?
                                These wires will probably need replacing. They are very hard.
                                Plenty to keep me busy!
