Project 'Can of worms'
  • s2driveruk
    • 12696
    Originally posted by Acidburn
    Is that each and would he be able to do different colours to black? Sounds quite good, have to see how your bits come out.
    I think he does batches of colour, when i spoke yesterday to him the next two days are black only.... I got the impression it was for both, didn't challenge it
    I'll post some pics up when i get them back
    1992 3b S2 Coupe
    • s2driveruk
      • 12696
      started work on the IM tonight while waiting for the other bits to come back from the painter... couple of photos showing before and after
      So this is how it started off
      After a degrease and wet & dry rub down, starting to show a bit of a shine
      quick initial coat of hi-temp paint
      offered up to the engine still need to rub down and layer the paint up...
      1992 3b S2 Coupe
      • Jon441cc
        • Dec 2005
        • 2061
        i have a feeling you wont be resting tools on any on those parts when putting the motor back in , nice work by the way very slick
        • Acidburn
          • 13459
          Looking good, soon you won't want to take it out incase you get it dirty again.
          • Fat Audi 80
            • 10547
            Once again, Nice.
            The Perfectionist
            • s2driveruk
              • 12696
              It's back in
              Been a long day sorting the last few things out, including discovering a nasty coolant leak on a return line from the turbo. Just happened to be removing the aircon compressor in readiness for James' replacement and saw something drip. The small rubber hose from the hardline was soaked and the jubilee had somehow failed. Anyway all sorted now.
              Took a good bit of wiggling to get the engine and box aligned but we got there in the end.
              Still tons to do but on the final straight now ahead of the Ring trip
              1992 3b S2 Coupe
              • Acidburn
                • 13459
                Some progress was made today
                  Wow, looking really good David! Wish I was able to make the Ring trip myself, not this year now for me I think.
                  • s2driveruk
                    • 12696
                    You betcha huge thanks to Peter for giving up a sunday to give me a massive hand getting the car back towards being ready for the road again....
                    So the engine went back in end of Saturday afternoon, engine was looking tidy ahead of the reunion with the bellhousing
                    Also cleaned/vacuumed and painted up the main rad and the intercooler - the amount of rubbish and grit which came out was amazing!
                    Peter arrived at midday and we started on getting some of the engine bay bits sorted, hooking up the sensors and getting the downpipe and wastegate pipes reconnected (easier than it sounds...)
                    We then set about changing the front top mounts and drop links, quick comparisson of the old and new blues...old one was off the drivers side looking pretty sorry for itself:
                    Usual problems with siezed bolts though the angle grinder made light work on the drop link
                    1992 3b S2 Coupe
                    • s2driveruk
                      • 12696
                      2/2:
                      Did the rears top mounts too and then set about trying to get the diff flanges off the replacement diff which i managed to round off. Managed to get the passenger side off which was relatively easy
                      Whole contents of the diff bar a couple of gear rings came out the other side after releasing the bolts on the casing
                      smacked a 12mm socket onto the soft hex head and finally a bit of swearing and a couple of roasted knuckles it let go
                      believe me, it don't smell good in there
                      The diff gears looked like new inside, no obvious wear anywhere. On a roll we started trying to get the knackered one off the car, but quickly fading light, p**sing rain and 2 driveshalf and one prop cv definately didn't want to let go of the diff, so we called it a day.
                      Next Sunday, replace the diff and maybe the prop, change the belts in the final push and this project will be........complete
                      Cheers again Peter, same time next weekend
                      1992 3b S2 Coupe
                        Looks like you have made good progress once again. It will be interesting to see what the inards of the old diff is like
                        • Acidburn
                          • 13459
                          Yup it will be, have a good go at getting the diff out and whilst its out maybe have a go swapping the prop over, I don't mind working under the car to get it off (may regret saying that) still the hard part is mostly over just gotta work out best way to remove the driveshafts now the bolts are all out then just drop it down swap the bits over and put it back up then put the front end back on.
                          Progress was good, all of the top mounts was not too hard to do, rears was very easy I thought, still hopefully next sunday should get a lot more done, i'll come down earlier to have a start.
                          • s2driveruk
                            • 12696
                            yeah i'll pull it apart and hopefully photograph it better
                            1992 3b S2 Coupe
                            • Fat Audi 80
                              • 10547
                              That engine is looking mint!
                              Keep going David!
                              The Perfectionist
                              • Acidburn
                                • 13459
                                Lol looks like I have a busy weekend next week
                                Yeah we have to change the driveshaft bolt flanges over between diffs, any tips for the pair of us to remove the driveshafts from the currently fitted diff?
