My 3B Coupe project - Total rebuild
This is a sticky topic.
  • DNA-S2
    replied
    In my opinion ....
    I don't think so mate
    I have seen several engines with 60+mph Cambelt failures and unless you have had rods bent and pistons destroyed including cylinder head chance of crack in block is unlikely
    Other components are there first to give/bend/brake first before block damage
    However we will never know for sure in your case mate
    Danny
    DNA Autocare Ltd
  • AndyP
    replied
    I was at Brian Tonks last night and forum member Farmerphil came up with a good theory as to why/how the block had cracked. I know the block came from an engine that has snapped it's cam belt and bent all the valves, if this had happened so number 3 piston took the brunt of the impact, could it have over stressed the number 4 main bearing, even starting a small crack which just continued to spread as I used it.
    Sounds plausable to me, your thoughts??
  • europeanme
    replied
    Originally posted by AndyP
    Crack on and build another!!
    good plan....
  • irishs2
    replied
    Impressive . My inner wing went in the same spot , although not as bad as yours
    Nice work on converting the fuel lines too.
    Very neat.
  • AndyP
    replied
    Originally posted by Error404
    Excellent, looks like you're getting comfortable with the AC mate
    Getting there, it's way harder that stainless though!
    I bought a cast inlet manifold off Ebay the other day, Rover 200 £9 delivered I'm going to cut it up and use it for practice on cast stuff.
    replied
  • quattrostyle
    replied
    Nice update, great work
  • Rocco
    replied
    Very nice work Andy and Tonks , as usual I'd say
  • s2_bo
    replied
    Awesome update!
  • AndyP
    replied
    Also part of the plan is to replace all the fuel line with teflon stainless braided AN6 lines, and they;re going to be run down the passenger side rather than the drivers side so this mean relocating the fuel filter.
    Part for the job
    Before I painted the battery tray I welded a plate on the side to strengthen it so I could mount the filter on it
    Then made a mounting from aluminium
    Bolted in place
    And fitted
    Welded some adaptors onto the standard fuel line to convert them to an AN fitting
    And finally got the correct fitting to conver the fuel tank to AN
    And I've also welded a new oil drain onto the sump so the breather system will drain into this rather than into the Fumoto valve
    I got all the fittings from this place on Ebay
    http://www.ebay.co.uk/usr/torques_uk...88.m1543.l2754
    Great to deal with, fast delivery and not too pricey
  • AndyP
    replied
    Time for an update with a bit of a positive spin to it! The car went off to Brian Tonk’s place the other month to have some work done on it, namely, ABY battery box installed, Vacuum servo fitted, ABS unit re-located and engine bay re-painted.
    Here’s the engine bay before
    Hole to be plated up!
    And here’s after Tonk’s magic wand had worked it wonders
    ABS unit re-located to the firewall
    Vacuum servo installed
    Battery tray installed
    Hole welded up
    I’m also going to put a vent from a T4 van in the wing to feed to air filter, so the inner wing has been cut out to allow cool air in
  • AndyP
    replied
    Originally posted by europeanme
    holy phuk matey...that has had some serious force pushed into it to crack that much in a solid casting.....
    any idea for your next move??....
  • europeanme
    replied
    Found out what the problem was with number 4 main bearing
    One small bit of good news is that the crank has been checked and is OK. Just need to start work on another block. FML
  • Seb20V
    replied
    Feeling sorry for you!
    BTW , it's a really nice car and it seems that you invested a lot in it so don't give up
    replied
    Jesus H!!!!!!!!!!!!
