My 3B Coupe project - Total rebuild
This is a sticky topic.
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    #481
    11:1 is way too rich though, so egt should stay low! Ultra safe but it could make more power. Up to which rpm did you go?
    sent using Android
    • AndyP
      • 6049
      It may have been slightly higher, to be honest I was concentrating on looking at the road as I was going quite quick
      Next time you're down here we'll have to do some runs with the performance box, then I can concentrate on the road and you can check the gauges!
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        #483
        That's a deal!
        sent using Android
        • AndyP
          • 6049
          Had a busy weekend working on the car, first of all I took it to Wabtech to get the wheel alignment sorted after a place in Sheffield f**ked it up. Will did a great job and the car is now not trying to kill me on every corner
          Performance and classic car specialists, UK factory approved Algema FIT-ZEL car transporter agent, marine engineering and crane hire with a PM 45SP crane. Whaley Bridge, High Peak.
          Also fitted the re-chromed headlights. Found they had made another error in plating the threads, not a big problem if you have an M4x0.7mm die nut ( which I do ) but if you don't it would be a show stopper.
          Just got to get them aligned now. Next up was the intercooler swap. I managed to bag this Wagner Evo intercooler from Twenty Valve on here
          Now I've got to dispute Wagners claims that it's a bolt on fit for the S2 bumper with no cutting required. My bumper had already been trimmed to clear the RS2 intercooler and I'm sure the new one would not have fitted if this hadn't been done. The biggest problem is that it won't allow the bumper up high enough, resulting in a huge gap under the headlights that looks odd.
            How much was it to get the headlight rechromed?
            • s2driveruk
              • 12696
              hmm, thats a nightmare Andy....great performance from it but asthetics less so. Those rechromed lights look good....how much did they cost you as they always yellow over time
              David
              1992 3b S2 Coupe
              • AndyP
                • 6049
                Headlights were ÂŁ160, for that kind of money I expected better attention to detail. I took some 'beam shot' pictures with the old lights, so as soon as the new ones are aligned I'll do some more so you can see the difference.
                Also just remembered that the Wagner intercooler has a bigger inlet diameter which means the Samco hoses are a REALLY tight fit
                • BRY
                  • 3755
                  #488
                  You forgot the driveshaft bolt story:
                  • AndyP
                    • 6049
                    Thanks for that
                      bolts coming loose?
                      I remember I was worried torquing them to 80nm I thought they were going to chear off, glad I did now
                      Headlights look great, as new... need new fogs now to match now!
                      Any pics of the headlight trim now its painted and fitted mate?
                      • AndyP
                        • 6049
                        Originally posted by Error404
                        bolts coming loose?
                        I put some pics in the other thread in the fabrication section.
                        Got a msg from the previous owner of the intercooler and he had to cut a hole in the bottom of the bumper to get it to fit
                          I remember Carsten saying about using the hose as it was designed to fit with the o-ring give him a pm to see if he can offer fitting advice
                          • AndyP
                            • 6049
                            If you're using this breather set up, do you need to use the one way valve or pressure regulating valve?
                              No, cos you're not connecting to the inlet manifold.
                              BTW Andy, the IC looks like it should go much closer to the crossmember.
                              • s2_bo
                                • Oct 2005
                                • 6067
                                #495
                                Can you trim the silicone hoses any more to get the IC to move further up? Or use decent orients instead?
                                91 S2 coupé - RIP
                                98 S8 - Luxury barge
