My 3B Coupe project - Total rebuild
This is a sticky topic.
  • Acidburn
    • 13459
    Originally posted by AndyP
    Hear hear! If he breaks it, I'll break him
    lol especially after all the work you did with the downpipe!
    That was a work of art, just a shame its now smurf blue.
    • prj
      • Mar 2010
      • 6308
      MAF can also be on the pressure side, especially with the 3071R...
      I guess I am a bit too late to say that. Don't hit me.
      It's a bit of a tight fit in the B3 and B4 chassis. A lot easier in the C4.
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        #543
        It's never too late to change things. Have you got a MAF solution for a 3076, pressure side, preferably in a 70mm tube? That would be perfect. You must already have a thread discussing MAF options somewhere.
        SS
        • prj
          • Mar 2010
          • 6308
          It will max out in a 70mm tube unfortunately on a 3076R.
          So the diameter must be bigger, at least as big as the RS4 MAF.
          Pro-M is a solution though.
          • SteveH
            • 4460
            Looking at the Pro-M stuff it's not too expensive and they make Maf's with built-in filters. Could be an option if Dmitri will map cars with them on. The 3" in-line tube version looks like an easy option for the pressure side.
            91 Modded 3B
            14 A6 Avant Black Edition
            • AndyP
              • 6049
              The rear wheel bearings have been grumbling for a while now so last weekend I thought I'd strip it down and also fit my H&R springs whilst I was at it. This seemingly simple job has now turned into a week long epic, due to worn out componants and a huge amount of corrosion
              First suprise I got was when I removed the rear struts, both Audi blue top mouns fell apart
              The bearing had separated from the rubber and all the balls fell out when I took it off. Next was the dampers, one front and one rear meant a full set was required. So I got in touch with Yaz on here and he sorted me a full set of Bilstein B6 sport dampers.
              This is what you get for using your car through the winter in England where they put tons of salt on the roads. These were blasted and powder coated
              These were blasted and painted with POR15, which to be fair has stood up well. But because I painted up to the thread I think water has got under the edge.
              Fresh coat of POR15 and assembled ready to fit
              Top tip when you're stripping the suspension, buy one of these off Ebay
              Search for 'digital angle gauge' they are about £20. Zero it on the strut before undoing the strut to hub bolts, then take a measurment off the hub
              When you re-buld the legs, simply set the angle back to what it was, then your wheel alignment will be spot on
              Front anti roll bar drop links had also failed, rubber had perished and fell apart when I took them off, now an MOT fail. So I made my own from some rose joints and steel bar.
              Should be road testing tomorrow
                The POR15 looks like its held up pretty well there Andy - did you coat it in Chassis Black afterwards?
                I have taken to jacking the car up and jet washing all the underside every few weeks in the winter. Its soul destroying to see all your hard work turning brown & crusty
                I thought you went back to stock suspension previously? Were stock dampers not available or fancying it a bit stiffer?
                • Kieron20V
                  • Mar 2008
                  • 1505
                  #548
                  Yeah, i had the konis off him, because they were too stiff..... Lol.
                  1994 URS4 Avant RS2+
                  • AndyP
                    • 6049
                    It did have stock Sach/Boge dampers, but after the last remap they were starting to struggle. Now that the car is not my daily drive I can live with a little discomfort in the name of improved handling. I think!!
                      hehe, good good. I guess you will need a bit more body control to reign in that power
                      • Avantus
                        • Sep 2007
                        • 941
                        • Country: Belgium
                        #551
                        Very nice!
                        It is normal btw that the bearing isn't attached into the mount, they are 2 seperate things
                        • quattrostyle
                          • Oct 2006
                          • 6229
                          Looking good again, especially those droplinks! well done
                          • AndyP
                            • 6049
                            Can anybody confirm if these look like the correct H&R's for a coupe?
                            They certainly don't look like these
                            The front seems to be sitting really low, the springs are almost coil bound just with the weight of the car on them. It's catching the wing on the RHS when turning and it seems to bottom out really easily at the front
                            • djh
                              • Jun 2011
                              • 1622
                              #554
                              Where did you get them from?
                              And I hope you can handle the bilsteins, going out in a car with them and hnr's fitted killed my back after only a short drive
                              • djh
                                • Jun 2011
                                • 1622
                                #555
                                They look possibly like 20v cq springs or even 10v one's rather than whats in the picture in re2500's post
