Steering arms have been left as I don't plan on lowering it a huge amount. Too many speed bumps around here
My 3B Coupe project - Total rebuild
This is a sticky topic.
Originally posted by A80Avant View PostIf that oil is going through the valves that way then doesn't that mean that the piston clearances may not be ideal?sigpic
I agree, for it to sit on top of the valves like that it has to be coming down the valve stems.
What's the definition of OK?
I use this system
All I get in the catch tank is a bit of mayo which is emptied every couple of months, anything else just drains back to the sump.sigpic
Not much progress has been made recently, mainly because I've been ill since the weekend when I pulled the head off, working for 20hrs in sub zero temperatures didn't do me any good
Anyway, the coilovers are finished and just need fitting, the head is back on and I just need to re-plumb everything. Should get most if it finished this weekend, then it's fingers crossed that the new VSOS fix the problem.sigpic
Originally posted by 4WheelDrifter View PostYou would think a 16mm cam cover breather should be enough. Hopefully those tighter feeling VSOS do the trick.
With my new 7A camcover I've made a bigger baffle to cover the breather outlet and hopefully stop it injesting so much liquid. I'll post some pics this weekend.sigpic
Welding finished and legs blasted
Treated with Metalready and painted with POR15
And finally fitted. It was sitting a little high at this so I've since dropped it down 20mm.
New Febi track rod ends also painted with POR15 and new Bambridge adjusters and hardware
This is the breather mod I did on the cam cover. 16mm breather welded on the back in stock position, needs trimming a little.
I've put this baffle on the inside so the oil does not have a straight shot down the breather under hard acceleration. Not sure if it will work or not but it's worth a try.
Will be interesting to see how the larger cam cover breather works. I added the 3B pipe fitting to my 7A head and it's still connected to the standard 3B breather setup. I'm not seeing any oil burning but there is a fair bit getting through to the Maf to turbo hose. I really need to update the breather system but there's so little room in the 3B engine bay91 Modded 3B
14 A6 Avant Black Edition
