My 3B Coupe project - Total rebuild
This is a sticky topic.
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    #616
    Remember to use glue on both sides on the headliner if you have bought the one with foam backing. It needs it!
    • andy10v
      • 5996
      Originally posted by AndyP
      I used this, with a matching primer
      http://www.ebay.co.uk/itm/1510594402...84.m1497.l2649
      Great, thanks.
      Looks good in the pictures, are you happy with the finish?
      Sold ABY-stock
        Can you put together a little forum how to when you do the headlining as I suspect there will be more of us needing to undertake this over the next couple of years
        • rynaqui
          • Mar 2012
          • 2752
          • Country: Malta
          #619
          Thankfully mine is in almost brand new nick, would hate to have such a job on the list . That and the heater matrix
          1996 S2 ABY Silver
          • AndyP
            • 6049
            I'm using this one:-
            Written by a forum member, Olly I think?
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              #621
              How is the trimming going? I had to add more glu on the rear good panel as it was coming off. Works well now
              • AndyP
                • 6049
                Not had chance to do any more yet I started cleaning all the old glue off the headlining panel last night, what a s**t job that is!! I'm not using the foam backed material like yours so the glue seems to be holding OK.
                • A80Avant
                  • Sep 2005
                  • 10873
                  • Country: Greece
                  #623
                  The foam would be easier to cover imperfections of old glue!
                  • AndyP
                    • 6049
                    Sunroof blind re-trimmed today. Also did the trim pieces around the edge of the rear hatch, forgot to get pics of those
                    See here for a how-to:-
                    • Tom_
                      • Oct 2007
                      • 1301
                      • Country: Czech Republic
                      #625
                      Nice headline work, Andy, can u compare on the picture,which color u have?I think thats a black,but i am not sure,its different shade...Thx
                      Audi Coupe Quattro 2.3 20V
                      • AndyP
                        • 6049
                        Yes, it's black. I bought it from here:-
                        http://www.ebay.co.uk/itm/1208167415...84.m1497.l2649
                        • Rusty
                          • 18953
                          Interested in how you get on...
                          • AndyP
                            • 6049
                            When I removed the interior A pillar trims almost all the mounting tabs broken nt sure if I broke them or they were already broken. I put a wanted thread on the forum but nobody had any with tabs in tact, so I decided to re-make them.
                            I had some 2mm aluminium so I cut some strips, hammered tem until they matched the profile of the trim, them cut a slot in and TIG welded ( not my best welding, need more practice on Ali ) a new tab on. Then I bonded them in place with polyurethane adhesive, checked them tonight after 24hrs curing and they are way stronger than the originals and they fit perfectly
                            Now I can get on with trimming them.
                              Awesome, I was wondering just the other day about the best way to solve this problem. What adhesive did you use?
                                That's brilliant, well done
