My 3B Coupe project - Total rebuild
This is a sticky topic.
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    #676
    That's a small turbo...
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      #677
      wow Andy
      what are you doing?
      you passed a great sunny sunday i see....
      i hope everything is OK
      • AndyP
        • 6049
        It to be so it doesn't break the clutch!
        • AndyP
          • 6049
          Originally posted by Rocco
          wow Andy
          what are you doing?
          Well it'd be no fun if you just drove it all the time, you have to pull it apart once in a while!!
          • AndyP
            • 6049
            Well that's a bit of a blow, looks like the engine could be scrap
            After the crank re-grind I fitted the new bearings and torqued up the main caps. The No. 4 bearing had somehow become crimped and was damaged. After fitting another set, I could only get to 40lb/ft on the mains before the crank become stiff and at 65lb/ft it locked up. Afte taking some measurements off the block is seems the block is bowed in the middle, meaning the main caps are ovaled, no. 4 being the worst. JP still has the cranks to see if that is salvagable, if not I'll be starting again.
            P**sed off is an understatement
              Say it aint so!!! I was just looking for this thread to find out how things were going
              • Tonks4x4
                • Nov 2005
                • 3062
                Oh mate, that is ****!!!! Just go for standard ABY bottom end and get some enjoyment...
                Tonks4x4 - The Land Rover Specialist
                Audi Nut!!!
                  Have you had the main alignment checked? You might be able to get the block align honed. ARPs do crush the mains slightly, so if your mains are out of alignment it won't take much to eat all your clearance.
                  • AndyP
                    • 6049
                    I was going to put my 3B engine back together and throw that in, but it needs about £400 worth of parts and then I'd have mess around getting the down pipe to fit.
                    I do have a spare AAT bottom end, but I'm just finding it hard to get motivated to do it all again!
                    • AndyP
                      • 6049
                      Found out what the problem was with number 4 main bearing
                      One small bit of good news is that the crank has been checked and is OK. Just need to start work on another block. FML
                      • A80Avant
                        • Sep 2005
                        • 10873
                        • Country: Greece
                        #686
                        Maybe these blocks can't take the abuse
                          ****! Never seen that before on an I5 - whats the history on that block?
                          At least you've got to the bottom of that and the crank is good. Did you find out what the oil consumption issue was?
                          • DNA-S2
                            • Sep 2012
                            • 369
                            I feel for you mate !
                            Danny
                            DNA Autocare Ltd
                            Danny
                            www.dnaautocare.co.uk
                            • Ross
                              • Aug 2005
                              • 3399
                              Gutted for you, was looking forward to an update here!
                              I know how it goes... I've parked the RS2 because I can't be done with dropping the sump on my driveway at the moment! Think I'd take a bit of time out, gather bits, then hit it when you get the motivation.
                                Jesus H!!!!!!!!!!!!
