Andy - Gsf do the head gasget sets £74 each.
My 3B Coupe project - Total rebuild
This is a sticky topic.
I've also sent off my spare set of ellipsoids to this place for re-chroming:-
Dual Metallising specialise in vacuum metallising, plastic injection moulding & spray painting for a range of markets including retail, brewing, automotive
In both sets I have, one reflector is better than the other giving a noticable better and brighter light, so I've decided to bite the ( expensive! ) bullit and get them re-chromed. Should be back next week, I'll post up some pics of the results.sigpic
1976 RD250E / 350LC cafe racerComment
Great find, how much was this? it's was done by a member a long time ago as an alternative to me buying a new set of lightsI've also sent off my spare set of ellipsoids to this place for re-chroming:-
In both sets I have, one reflector is better than the other giving a noticable better and brighter light, so I've decided to bite the ( expensive! ) bullit and get them re-chromed. Should be back next week, I'll post up some pics of the results.Comment
Got the headlights back from re-chroming and there is good news and bad news! Good news is that they've done a brilliant job on the chroming, bad news is that they broke one of the mounting lugs. It's been glued back on and as it's not load bearing, should be OK.
Here's the before shots
And the after
You can see the broken lug in the top left of the second after picture
Cost was £160
Not cheap I know, but as you can't buy the reflectors from Audi I didn't have a lot of choice. I'm hoping the extra light output will make it worth while. I'm even thinking of buying some 75w HID's to compliment them:mischeif:
Oh yes! Did you also see the mrc video? You are in that a couple of times. Camera likes you! Haha
By the way, looks like about 30% of meth will make the mixture slightly more rich, so either use less or make a dual map.
sent using AndroidComment
Not seen that video before, I'm keeping out of the way next time
Car was mapped with the meth on so it should be fine, in fact I did a flat out 6th gear run uphill on the way back from Brians and it was running at 11:1 with a 780°C EGT.sigpic
