Originally posted by Sonic
View Post
Project: RS2 ABY
Just want to stick my 2p in, I am not a fan of lightened flywheels either. I prefer the torque inertia given by the heavier wheel.
With lighter flywheel the Rpm drops way faster
Tonks4x4 - The Land Rover Specialist
Originally posted by A80Avant View Postthis has gone way past RS2 ABY project....
Originally posted by Tonks4x4 View PostJust want to stick my 2p in, I am not a fan of lightened flywheels either. I prefer the torque inertia given by the heavier wheel.
With lighter flywheel the Rpm drops way fasterS2Forum.com Administrator
Originally posted by Error404 View PostYou must have mutant feet if you can comfortably heel & toe with the S2 pedal box
I am having to modify my accelerator pedal to make it easier.
Shoes aren't my kinda thing when driving1996 S2 ABY Silver
I was thinking about how to change the pedals to make it easier.S2Forum.com Administrator
Going to shot blast and paint it once I'm happy with the shape and position.sigpic
Love it Andy!
Luckily the s2 doesn't suffer from massively over-servo'd breaks like it's later cousins, but the pedal position is massively out. It makes the BMW a doddle to drive in comparison though, even if the brakes are less progressive and overly sensitive.S2Forum.com Administrator
The S2 is heading up to VRS later today for the latest round of mods:
Gearbox synchro's replaced
Front brakes sorted (maybe discs warped or calipers binding)
Billeted steel flywheel to replace the OEM dual-mass currently fitted
Aquamist kit for WMI (need to decide on separate tank or not)
7A cams and ABY pulley to replace ABY inlet / RS2 exhaust and vernier pulley currently fitted
Possible inlet change from RS2 airbox to cone filter if the airbox proves to be a restriction
Can't waitS2Forum.com Administrator
Some good plans there, but you wil almost certainly lose power with a cone filter.
Done power and temp measurements on the road of multiple cars, and the result is always the same, the powercurve gets visibly knocked down with the cone type filters.
The RS2 box is well designed and has very little restriction.1995 RS2 on Alcohol (6.8sec 100-200km/h)
1994 80E Avant
1986 2L Golf 2 on Alcohol
Thanks, it sounds like this mod isn't really worth doing then and your findings meet with what several others have said.
How come the cone filter seems to cause less power though, surely at speed the flow is increased and there's minimal heat-soak with proper shielding in place?
I do like the RS2 airbox, it's just such a PITA to get into with the clips
My initial thought was it might be a restriction on the inlet, but if that's not the case then i'll happily keep it over a cone.S2Forum.com Administrator
