Yea, it is running too rich, that's why I keep saying that you have a boost leak.
Project: RS2 ABY
I have to say, boost check is mandatory on these cars, I was so certain I had no leaks on mine but still we found several unexpectedly when mapping. it was silly small things like a tiny leak on the back of the head (breather system), and the IM injector seats that made a huge difference and were only found with soapy water and some air pressure in the intake!
No point judging that clutch until you've got another 2-300 miles of non motorway driving on it either, it'll be like stock eventually just a bit heavier. For the time being stop being a wuss
I'm very interested to see how this compares to my car as well, with that reverse intake manifold! Top end should be similar but I'm seeing 2.2bar in teh midrange in 2nd gear upward thanks to lower compression so I'm confident of taking the Torque title
Well you need to get up to mine Ross, to help me with that oil change and checking for leaks
I do have a fairly comprehensive catch-tank system on it now which would provide lots of places for a boost leak, as well as the car being put back together in a hurry on friday night.S2Forum.com AdministratorComment
Yeah I had the same with the nipples, they are being replaced with beefier connections
I spoke to Carson about the fuel bolts as mine weren't drilled far enough so I'm planning on use the old gas tape on the bolts and drill through so I wont have a petrol leack again
As promised here's a link to a video of the diagnostic outputs we were seeing while running the car in:
The car definately smells like it's running seriously rich.Haynes Manual:As described in Chapter 7...
Translation:That'll teach you not to read through before you start, now you are looking at scarey photos of the inside of a gearbox.Comment
500 miles on the clock, the clutch now feels great and i've taken it up to 6krpm tonight
The stalling issue seems intermittent but does seem to be getting better, i haven't stalled it in 2 days now, but the temperature reading is still way off
The bad news is that the peak figures on the zeitronix were 9.6 AFR and 22 PSI (1.5 bar), so boost seems a little down from what i was expecting on the run-in map, not a problem as it'll be mapped correctly, but it's definitely running way to rich which you can feel when you try to push.
Not sure where to start on checking for boost leaks, but now that she's run-in i can look at getting that sorted, along with changing the filter and filling with fully syth oil.S2Forum.com AdministratorComment
Uhm, it's a pretty big problem, because your car can not be mapped with boost leaks.
So take care of them.
The reason it is running so rich and not hitting target is the same.
And the way to check for boost leaks is to pressurize the intake while blocking off the PCV.
No other way.
Look, to make perfectly clear - it is not the tune that is at fault. Your car has to run perfectly (albeit with conservative boost and timing) on this tune, if it does not, then there is a problem with your car.
You should never see below 11 AFR at all, and boost should be at 1.8 bar.Comment
LWB Audi Sport Quattro projectComment
