Mr Simmonds 3B lite project.
  • andy10v
    • 5996
    Another thought as we are now dealing with an unknown chipset (and unknown hardware requirements or fuelling)
    (In reference to TS RS2 map)
    Originally posted by prj
    I'm gonna rain on your parade, and say that this chipset is made for race fuel or meth injection, and that if it's running 11.5 AFR it's knocking all the time, as it's mapped to run a lot leaner than that without knock. It needs at least 102 RON to run knock-free. The knock maps are heavily upped as well, dumbing down Motronic's knock detection.
    The 0.2 bar in fuel pressure won't take it from 11.5 to mid 12.
    Also, that rolling road is pretty optimistic. I know my personal custom maps don't make much more than 370, and as some people can attest on here, my personal maps produce lower FATS times (Lloyd's car went from T+S to my map, got extra hp, less lag, better mpg, etc.).
    "Generic" and "safe" don't go in one sentence with the T+S 1.9 bar chipset.
    Sorry.
    That said I think Rusty ran TS on his on ABY for 3 years, Rocco on his 3B etc
    Sold ABY-stock
    • K Simmonds
      • Dec 2007
      • 7627
      I think Rocco can still supply TS 3B ones, I had a set but sold them as I was so happy with performance from the ECU I got from Kibby I couldn't be bothered to try them which in hind sight was a poor decision.
      Another option is a different known chip set
      What's set's in yours and do you know where it can be acquired?
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • andy10v
        • 5996
        You may well have TS chipsets already fitted from Hoffer? I thought that is where Rocco got his from?
        Sold ABY-stock
        • K Simmonds
          • Dec 2007
          • 7627
          Good point, guess I need to open up the ECU and see if their marked in anyway that could ID them.
          1994 MTM RS2.
          2000 B5 TQS.
          • andy10v
            • 5996
            I take it they dont say anything in vag com?
            Sold ABY-stock
            • K Simmonds
              • Dec 2007
              • 7627
              This is all I get mate, how's it compare to yours?
              Address 01: Engine Labels: Redir Fail!
              Control Module Part Number: 857 907 404 B
              Component and/or Version: MOTOR PMC 1
              Software Coding: 0261200453
              Work Shop Code: 1267356261
              VCID: 1E39DDF29A73A9EE89B-4B00
              1994 MTM RS2.
              2000 B5 TQS.
              • K Simmonds
                • Dec 2007
                • 7627
                Stuck the 4 bar regulator back on, back to low tens with brief excursions into the high 9's if it's really pushed, though it backs off into the 10's if given enough space to keep the throttle open. Still goes like stink. Cleared the codes and fitted the new throttle cam I got from Nip and adjusted the damper. Took her for a quick blast and all seems well, no fault codes upon return.
                So it can stay as it for now and I think I'll get it live mapped in future.
                I could try and adjustable FPR but that's not really a proper solution and it could go wrong.
                Really impressed with the quality of this, very nicely machined.
                1994 MTM RS2.
                2000 B5 TQS.
                • andy10v
                  • 5996
                  The TB cam looks nice.
                  Does PRJ do 3B RS2 chips with a known hardware setup?
                  A live map for your car if this is the final engine setup is the way forward though.
                  Sold ABY-stock
                  • K Simmonds
                    • Dec 2007
                    • 7627
                    I'm not sure if PRJ still has anything to do with 3B's at all, I guess I could drop him a brief PM.
                    A live map really is the way forward, I like this current set up and can't see myself getting bored with it for some time, especially as I know it would go even better leaned out a little.
                    I also suspect this chipset maxes out the injectors which isn't ideal.
                    1994 MTM RS2.
                    2000 B5 TQS.
                      PRJ doesn't want to do any more 3Bs, he says they're a pain in the butt.
                      • andy10v
                        • 5996
                        I know PRJ wont map 3B, but he might have a good 3B RS2 setup for RS2 injectors, turbo, and a known fuel pressure?
                        Money would probably be better put towards a live map though.
                        Sold ABY-stock
                        • URquattroGus
                          • Aug 2007
                          • 547
                          Ah Boriss, when will you ever learn.....
                          Angus
                          (1984 ur quattro)
                          • K Simmonds
                            • Dec 2007
                            • 7627
                            1994 MTM RS2.
                            2000 B5 TQS.
                              Eh?
                                Kit can you do a pic of where the throttle cam fits down behind the butterfly operating arm? To get mine to fit in there I have to open the throttle slightly, is this correct? In other words the tang on the throttle cam is thicker than the original.
