How have you removed the tar panels? Did you use a hairdryer/heat gun?
I was also thinking about re-routing the washer bottle as it should remove up to 5kg from the front and leaves weight in the back, something that it needs when all stripped! My rear wheels spin a lot easier on a launch than they used to
With the thick rear bar it was always lively on track but good on the road, seems to tuck the front in nicely at the moment too but I'd bet on track it'll be a handfull, I'm hoping that the HnRs tame it a little, I'm sure that the semi-slicks will.
There is some felt under the tank cover though.
