3b s2 coupe resurrection
  • terrybullwon
    • Mar 2006
    • 8782
    I have the same horse box here!
    Chef
    • andy10v
      • 5996
      It was for my sisters horse, I use it for storing stuff
      Sold ABY-stock
        what kinda grinding stones did you use on the manifold Andy?
        • andy10v
          • 5996
          £5 from halfords ones
          Seems to work fine, can grind of the lumps, smooth things out and radius bits.
          Used them in an electric drill so far, ordered some smaller shanked stuff to use the dremel to reach inside, just hope it has enough juice or an air die grinder will be on order.
          Sold ABY-stock
            cheers mate
            • andy10v
              • 5996
              Tools;
              Drill with stone, removes material easily and relatively easy to control, however doesn't get very far in and you don't want the chuck to hit.
              Aldi dremel with flex extension Nice and easy to get in akward places and accurrate to use, however takes ages to remove anything big with a stone, might try a carbide bit.
              And a few random pictures of starting to smooth things out
              Sold ABY-stock
              • rs200
                • May 2009
                • 1398
                • Home: Croatia
                #232
                is that good? have that procedure some effect on exhaust gases ?
                I did same job with IM , and now I thing it was waste of time and money..
                • andy10v
                  • 5996
                  The idea is to improve exhaust gas flow and hence effeciency. This casting is not great so I beleive a few hours work is worth it.
                  I am just cleaning up casting imperfections and smoothing out things, I am not radically changing the shape of the runners. I don't have enough knowledge to do that.
                  Sold ABY-stock
                  • bikerjim
                    • Feb 2008
                    • 1028
                    Its well worth it, takes ages but V satisfying. I did all my 16v head with a dremel lol
                    • andy10v
                      • 5996
                      Adapter for egt probe (downpipe boss is m12, egt is 1/8 npt, you can get adapters on ebay for about £8)
                      Got the egt probe in and the gauge wired up, its backlight blue so going to take it apart and try some red LEDs.
                      Sold ABY-stock
                      • andy10v
                        • 5996
                        Probe
                        Guage
                        Done
                        Sold ABY-stock
                        • andy10v
                          • 5996
                          Managed to get hold of a k26/6 944 turbo for making a k24 7400 hybrid thing.
                          Still to get; a cobra head hose for the intake, uprated fuel pump; 044 or the ebay £50 one prj has used.
                          Software;
                          Automark £400
                          MRC£??? was about £700 plus vat i think
                          Bahnstrom £320
                          s2 Central ?
                          prj ?
                          porkkis-300e (chips)
                          Getting a tuner to me would be expensive, traveling to a tuner adds fuel costs but the tuning needs to be done right.
                          The s2 developed a bit of slop on side to side load transfer, so started investigating;
                          Strut top compressed, doubtful if the cause of the movement though, got uprated spares so fit anyway;
                          (I don't know what mounts these are, bought them second hand unused on the forum, but they fit perfectly, no slop like some others have had with the 034 mounts.
                          When fitting the top mounts I had a look over everything else and one of the wishbone bushes is shot I know they have been on borrowed time as the looked tired but the car was driving well up to now. I have a couple of bushes in the garage so will probably just pull that wishbone and rebush it to keep the car driving nicely. However it means the car is up for re bush
                          So parts list, a few options for each, asterisk if I am leaning that way
                          Top mounts;
                          Pro mounts*
                          034
                          2bennet
                          compbrake
                          oem
                          Wishbone bushes;
                          powerflex*
                          superflex
                          cheap ebay poly bushes
                          oem
                          Subrame bushes
                          superflex*
                          alloy-babmbridge
                          alloy offset-034 (for castor)
                          oem
                          Balljoints;
                          oem
                          Track rod ends;
                          oem
                          delrin inner bushes (bambridge)
                          Rear tie rods;
                          oem
                          ARB bushes
                          superflex
                          powerlex*
                          oem
                          Droplinks
                          oem
                          Anybody have any advice? What about powerflex or superflex, any preferences?
                          Might weld wishbones and subframes when I have them off; free upgrading, get some por15 and join the club Also see about a fr to rr arb ala error404.
                          This might get done in stages, new wishbone bushes as I can replace them without an alignemt, then collect the bits to do the rest in one go.
                          Sold ABY-stock
                          • Jeltuh
                            • Oct 2007
                            • 73
                            There is no need to do more since the restriction is mostly in your head and not your IM or EM. Nice job, it's getting to an end!
                            • andy10v
                              • 5996
                              Porsche 944 220bhp k2/6
                              Snapped 2 studs getting the downpipe off
                              Other two undid fine, so roast the two snapped ones? Weld a nut on? Hit them with freeze spray? Any suggestions appreciated.
                              Hotside off
                              Porsche hotside sitting loosely on volvo unit.
                              The porsche unit used spreader plates like on the audi prop between the bolts that hold the hotside on, the volvo unit used single tabs on each bolt, whats best to refit?
                              Sold ABY-stock
                              • Knight Rider S4
                                • 3541
                                drill hole through strong angle iron (slightly angled so it doesnt hit other studs when revolving ), slide over broken stud and weld to it stud , this will give you direct purchase to turn it rather than relying on a nut which you have to attach socket so on
                                Good luck
                                93 S2 Avant Parting
                                91 URQ RR
                                02 A4 tdi Avant
