My S2 coupe
  • quattrostyle
    • Oct 2006
    • 6229
    Originally posted by Error404
    Dash has probably droppped. If you loosen the two little bolts behind the covers in the door jamb you should be able to push the dash up and retighten the bolts with it in the right position
    at least that's not the case on LHD models, only dual airbag models seem to line up correctly.
      Just tried this on mine, looened the bolts and got my knee under the dash and retightened, much better but not perfect.
      Oops I think there's a thread hijack happening!
        Originally posted by TimE-J
        Just a quick update,
        Fitted a new 710n recirc valve as old one failed earlier in the week.
        Anyone know of a good paint silver paint that looks factory so that I can paint the IM and rocker cover, does it need to be high temp paint?
        Why not bead blast and laquer, or polish?
        • TimE-J
          • Jul 2009
          • 1292
          Dont worry about the hijack!
          Yeh hadnt really thought about it, i dont want it to look realy shiny just what it too look clean and new!
          96 S2 aby Coupe. Rebuild Project
          96 mk3 golf tdi daily.
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            #50
            To further the hijack: I seem to remember there are screws on the tops of the doors to adjust the height of the door cards.
            SS
            • TimE-J
              • Jul 2009
              • 1292
              I not 100% sure so dont shoot me down but im sure he means that instead of the door card and the dash edges lining up height wise i think he means that the dash sits further forward.
                Really?
                • Nuvo
                  • Nov 2003
                  • 3825
                  #53
                  There are two large nylon bolts at each end of the window regulator for adjustment of the door card.
                  • Big Lee M
                    • 2571
                    I think you can get matt lacquers now so would look good bead blasted.
                    Just some finishing touches to do now
                    • Dingo
                      • Jan 2008
                      • 229
                      I did mine in satin finish lacquer
                      • TimE-J
                        • Jul 2009
                        • 1292
                        Cheers guys, thats the look im after.. do you remember where you got the lacquer from?
                        • s2_wot
                          • Aug 2006
                          • 2178
                          #57
                          liking the way this car is working out, very tidy motor.
                          Shane
                          • TimE-J
                            • Jul 2009
                            • 1292
                            out for a drive tonight and managed to pop a water pipe. It looks like its one of the pipes that comes off the water rail and goes towards the front of the bay but its to dark now to do any proper investigation so it will have to wait until after work tomorrow. Ill update more when I find out the problematic hose!
                              Probably the short piece going to the steel pipe that sends the water round the front of the motor to the turbo.
                              • s2_bo
                                • Oct 2005
                                • 6067
                                #60
                                Yeah sounds like it. Right PITA to get your hands down there to fit a new one too!
                                Its always baffled me why they didn't just make a solid hardline all the way to the banjo.
                                91 S2 coupé - RIP
                                98 S8 - Luxury barge
