OEM+ Coupe 16v (1.8t on the way)
  • Val
    • Apr 2008
    • 630
    • Country: Latvia
    #76
    - why no OBD pins from your ECU
    - why no MIL from your ECU
    - ECU connector C pin #12
    - don't have it
    - RPM signal either from ECU connector C pin #10 or T10M/2 (blue/green)
    Edit: didn't see excel file on previous page
    5vtq gte
    • sam80quattro
      • Oct 2006
      • 1496
      this helped me with my 1.8t swap
      Hey all, well once again my bored adventures have led me to create an AEB to CE1 wiring chart, if someone could help me and reassure that all of the ones with ???????'s are correct on here http://www.a2resource.com/electrical/CE1.html fill in the blanks if you can. Thanks Modified by jhax at...
      also autodata has pinouts for the ecu, pretty sure green/black was the wire colour for diagnostics port, and it just needs 12v and an earth after that
      got vagcom working nicely on my 90
        #78
        Ahh yeah - could be one of those ECUs that just uses K-wire... I have annotated the spreadsheet again.
        • bikerjim
          • Feb 2008
          • 1028
          I have got hold of a later style (1997) ECU and loom with only 2 large plugs that go to the ECU. Im not using the earlier 95-96 5 plug type.
          • bikerjim
            • Feb 2008
            • 1028
            Cheers sam
            • bikerjim
              • Feb 2008
              • 1028
              Cheers paul, im going to have another play with this today. I'll report back later
                #82
                Jim - what is date on that AEB loom ?
                • Val
                  • Apr 2008
                  • 630
                  • Country: Latvia
                  #83
                  5vtq gte
                  • bikerjim
                    • Feb 2008
                    • 1028
                    97 paul
                      #85
                      Sorry to be ****. I need the actual date stamp. Saying 97 could be MY96 for instance or even MY98
                      • bikerjim
                        • Feb 2008
                        • 1028
                        oops sorry my bad.
                        On the white labels there are a couple of different dates
                        T10 has - 04.12.97 & 03 or 09.07.97
                        T10m has - 09.07.97 & 12.11.97
                        Hope that helps.
                        Got my head around how to wire up the fuel pump now, gona put some words down a bit later if you wouldn't mind checking it for me pls
                        • bikerjim
                          • Feb 2008
                          • 1028
                          Fuel Pump Relay
                          Is this correct Paul?
                          I can use existing relay making the connections as bellow?
                          Connections -
                          1. BS on CEP to ro/bl T10z/6
                          2. O on CEP to 20A fuse (placed in an aux fuse position at fuse box) to ro/gn T6z/4
                          3. 87a on CEP replace 0.5 gn/sw with 2.5gn/sw to S25 (replace 5A with 10A fuse) then to 2.5 gn/ge T10z/8
                          lol hope that makes sense.
                            #88
                            Will check your words later but looks encouraging.
                            Btw - that date is for an My98 car. This might explain the few loom differences - will look at that again soon.
                              #89
                              1 - yes
                              2 - yes, but you could also insert a new fuse in the main fusebox for this... should be some spare positions in your ACE motor
                              3 - yes
                              Connections -
                                #90
                                I have been using the later set of diagrams you have on your site for the 94 coupe ACE C49, this may be wrong, I have noticed very few differences but there are some.
                                Just remembered about this too... C49 is for July 1994 onwards i.e. MY95
                                If the ACE engined car has 'R' in the VIN then its MY94 - so go with B71 as best schematic to work from
