My 3B project (ongoing)
    A few of us have had this issue, mine was leaking from the small pipe just below the main filler in your picture, fixed it with that chemical metal stuff a few years ago and fine ever since.
      Fuel Tank Breather System - Coupe
        • Bowie69
          • Nov 2013
          • 2681
          Yes, exactly the same issue here, wire wheeled it to bare metal and chemical metal putty round it has fixed it for years now.
          • Dobby84
            • Feb 2011
            • 1169
            Thanks for the fast reply. I'll pass this info on to the guy who is looking after the s2 and sort it out as soon as possible.
            Could this cause starting issues? Car was starting fin the other day bit it just turns over but doesn't start?
            • Bowie69
              • Nov 2013
              • 2681
              I would say very unlikely.
              • Dobby84
                • Feb 2011
                • 1169
                cheers
                  Would think not, mine ran fine just very smelly
                  • Joss
                    • Mar 2019
                    • 8
                    Hi all. I’m “the guy” that currently has dobby’s S2 stored at mine and will be helping him put it back together. Thought I’d join so I can see info and ask questions to save going back and forth. What he hasn’t told you is I’m his pain in the **** best mate who has plenty of his own projects but can’t help sticking his nose in . So far we’ve sorted a couple of niggles with a leaking turbo oil return feed pipe and a door that wouldn’t lock when you refitted the door card. Turned out the cable sheath on the internal handle was just slightly too long causing the lock to not operate. I’ll be looking at his fuel leak and headlight wiring over the next week or so.
                    This gallery has 4 photos.
                    • Dobby84
                      • Feb 2011
                      • 1169
                      He a bloody good mate!
                      Second time your BMW has graced this build thread
                      • Joss
                        • Mar 2019
                        • 8
                        It just gets everywhere doesn’t it
                        • Dobby84
                          • Feb 2011
                          • 1169
                          Was playing with the car this weekend and for some reason it has decided to not start.....again....
                          Turns over but fuel pump doesn't have power, and no spark. Is there a way I can check the sensors easily? I don't have a code reader with me here in Bournemouth as I forgot it.
                          • Bowie69
                            • Nov 2013
                            • 2681
                            I used to get that occasionally, often after a long hot run.
                            In the end I swapped out the two crank sensors for new ones, and never had the problem again.
                            Without a spark, the fuel pump won't run, safety feature
                            • Dobby84
                              • Feb 2011
                              • 1169
                              My car doesn't go anywhere but it did run fine
                              • Bowie69
                                • Nov 2013
                                • 2681
                                Well, stick a multimeter across them both, and check for at least similar impedance.
                                Otherwise it is the usual things, like check your rotor and cap, coil connections, power to coil, ecu power. Not much else it can be apart from a fried ecu, which is unlikely.
