Originally posted by newsh
View Post
My 3B project (ongoing)
As the battery will now be located in the boot I need to buy everything to complete the job.
First of all I need a battery, looking at a Bosch S battery but I'm confused to which one I should buy, 4 or 5 and what Ah I need.
I need new cables too but again I'm not 100% sure on the size, maybe 50mm2?
Going to add new connections, a 150a circuit breaker near the battery, a cut off switch to be mounted on the dash and a positive jumper post under the bonnet. The ground will be on one of the bumper bolts on the NS in the boot, a new ground from bell housing to the chassis. Not sure if I have missed anything but feel free to add anything.
Battery Wiring
I am thinking about routing the battery cable
url]http://www.ebay.co.uk/itm/231576302890?_trksid=p2060353.m1438.l2649&var=5308 12093479&ssPageName=STRK%3AMEBIDX%3AIT[/url]
through the bulk head near the original battery location then swapping the current positive connectors with one of these
http://www.ebay.co.uk/itm/1618420306...%3AMEBIDX%3AIT
and connect to one of these mounted on the old batter tray for jump starting.
http://www.ebay.co.uk/itm/3016855694...%3AMEBIDX%3AIT
I also plan to install this
http://www.ebay.co.uk/itm/Battery-Is...4AAOSwv9hW3r5Q somewhere on the dash using the same connectors.
Originally posted by Dobby84 View PostSo I may have the right pipe? Just seems odd that the hose doesn't really fit
Sent from my HTC One M9 using Tapatalk
Originally posted by Error404 View PostI think I used 25mm2 cable for the starter, and 16mm2 to the fuse board on my battery relocation.
I've always used Varta batteries. My last one lasted over 7 years.
Originally posted by Rikki Kitto View PostI had nightmares with similar clamps, boost leaks galore so went back to standard type jubilee clips Give it a good check over they don't seem top nip up with the wide fittings
I used one of these in the engine bay, seemed like an easy way to extend the battery wiring, and give a jump point in the engine bay.
I cut the battery clamp off, and fitted ring end
Ran the cable down the passanger side and through a firewall grommet.
Battery tray cut out is great, so much more space for access.Current-2004 Impreza PPP wagon
Sold ABY-stock
Originally posted by andy10v View PostI used one of these in the engine bay, seemed like an easy way to extend the battery wiring, and give a jump point in the engine bay.
Just an ebay one
http://www.ebay.co.uk/itm/12V-24V-JU...QAAMXQLs5RuF~s
You can get OEM ones from some BMWs.
Do you have a way of crimping or soldering new ends on the cable?Current-2004 Impreza PPP wagon
Sold ABY-stock
Right,
Need to make a decision on which battery to buy. I have found the following on eBay but cant decide, may come down to price at the end of the day. Any thoughts?
Bosch S5008 - £83.99
Bosch S4010 - £78.99
Varta E11 - £63.99
Varta E44 - £67.10
