My 3B project (ongoing)
Good work.
The really long squiggly one goes from the bottom of the header tank, through the oval hole in the ABS bracket and down to the bottom of the rad.
Show us a pic of your rotor arm, I'm not sure if it's the correct one.
Originally posted by Dobby84 View PostI'll take a pick tomorrow. Has been working fine
Sent from my HTC One M9 using Tapatalk
Are you running the aux rad?
It looks like top front of main rad to top of aux rad.
Looks like I may have the wrong one one there, I bought a spare from quattro corner a while ago which looks like this.
Shall I change it over? I have a new cap to put on too.
May as well change both I guess!
Fitted my Performance Friction pads today just need to bleed them up.
Also got the steering arms back on and roughly adjusted for now.
Got the old plastic injector cups out apart from one which is being stubborn
Started to take the exhaust off too and found that the car isn't high enough to remove the downpipe which is frustrating, not sure how to get around this one!
Sent from my HTC One M9 using TapatalkLast edited by Dobby84; 25 October 2015, 16:10.
You need to be running the narrow rotor tip. You can cut the wide one down if it's in better nick
