perfect project, love that look... what rear brake setup u ran? Engine bay looks clean as well, i hope, that i build my 20V 7A engine like your 10V... Stunning
Acq 10vt - oldschool turbo power
waky waky ol' girl
lots of bits upgraded/improved - time to blow dust away.
will try to measure it on weekend, but it uses almost all space in the rear to fit...
summer ended and it was like a blast
found a big leak via injector O rings. Went to check if any changes and still got same power. Dyno showed 2.2bar boost@ 3800 rpm with oldshool HX40 and #12 housing
after a while snapped front driveshaft when accelerating in 2nd gear
Have changed WG spring to some stiffer one - gear change boost response has increased, but have little overboost issues now - will need to tweak PID control a little.
Converted COPs to TFSI ones. Plug gap increased to .8mm and is boosting fine.
thinking about making my own Intake manifold in winter, maybe try another cam
