Well found the source of the loom meltdown, 20 year old alarm system, now all removed no more issues with my electrics thank god it was getting a bit scary
The S2 is dead, long live the S2
Originally posted by Fat Audi 80 View PostGood news. I have a gremlin in my standard Audi Alarm which needs chasing down...
Went out to use the Avant yesterday, opened the door and the honk honk from the boot went off! Then I realised the drivers door isn’t locking or unlocking the other doors any more.
Any ideas?
I’m thinking it might just be the switch in the driver’s door.
Problem is the key doesn’t open the oth side or the boot, either there’s a different key which I don’t have or they’re seized from never being used..
Sorry Rikki! Thread hijack
Well done for sorting yours!
Originally posted by newsh View Post
Me too!
Any ideas?
- 2 likes
Originally posted by Colesy View Post
There's an actuator attached to the lock that activates the central locking system. The best way to see if it's a faulty actuator is to get a spare actuator. Remove the door card, unplug the actuator and plug in the spare to see if it then works. If it still doesn't you probably have a wiring issue. I found a broken wire in the rubber wire cover at the door hinge when I had the same problem. This way saves you dismantling the lock unnecessarily like I did! Or you could check the wiring at the hinge to start with, might save you some time!
If that all looks ok then I’ll pull the door card.
I’ve got a spare actuator from an ABY coupe somewhere in the cave..
- 1 like
Originally posted by Rikki Kitto View PostJust ordered this too as my 3 month old new one is leaking from the top edge
I can highly recommend Collin here: https://www.facebook.com/captaincoll/
Had a rad from him in 2016 and it is top notch. Some more details here:
https://www.s2forum.com/forum/techni...roup-buy/page3
Stick with the stock fan though!
It was the switch on the door lock not making contact, replaced with a spare and now all working.
- 1 like
Just finished fitting the 13 row oil cooler, great upgrade if you have deleted the aux rad. Feels much better having it in a place you can keep an eye on it, always thought the original position was a bit strange. Trying to upload pics but message says file too big so will update it when I can
Originally posted by Rikki Kitto View PostAges since I updated my thread life getting in the way as always anyhoo think I've found the starting issue
