Great work!
Andyg's Colgate Wagon Project thread
Originally posted by bartolomeus View PostI've changed the water pump on my car as well but the metal part you have all rusty in the picture it was from plastic on my pump. I don't understand why your pump has that part from metal
Good luck with the project Andy!
Well only a small update as I barely have had any time to work on it.
Engine out and I removed the sump to inspect oil pickup etc and all seemed well no blockages etc.i removed the oil breather pipes to clean and oh my god were they choked up ! All now cleaned out and refitted so am hoping I am done with any smoking issues.
Waiting on a clutch to arrive from Ireland then it's ready to be put back in the car, how some people keep their cars off the road for months at a time I do not know,mines been off just over a week and I'm missing it already !
is the rear seal just a lip seal or is there a steel collar to be ressed to the crank as part of it ? mine is pretty much the same mess as your when i split the box and engine. can it be fitted without a seal press1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
The rear main seal ?
I just tapped a screwdriver in and got the old one out then removed the housing flipped it over and delicately tapped the new one in from the rear,hardest part was refitting the flywheel as it wasn't just a case of bolt it back on as some of the holes were offset so the flywheel itself had to go back on in exactly the position it came off
s2
Originally posted by dest View PostBut what did you do with it in all the time that you owned it?
I cant believe how slow things take on these 'projects',it takes most of the day to rip an s2 engine out minus a ramp etc and yet it seems to take days just to clean all the parts before reassembly
So today I finished off all the pipework for water and breather system,replaced the thermostat housing elbow etc.Finally fitted the RS injectors along with new mfts and temp sensor
Whilst I was there I put on a cleaner inlet manifold and scrubbed it in Ardox cleaner.Took the exhaust manifold off to fit my RS item,this pretty much took me all day as I thought I would take my time and clean everything.It was so caked in oil from previous leaking rocker gaskets,seals etc
Roll on when I can find time to fit the new turbo,and also the 3b clutch thats had issues with the couriersLast edited by andyg plym; 5 November 2012, 20:09.
