I think LHD are still available from VAG but also widely available on eBay (mostly from Latvia it seems). Not sure of part numbers though.
Sport Quattro
Good to hear you are starting to gather the parts up, the first of many! Shame to hear that the Recaro's got damaged in transit.
That's a stroke of luck having another chap close by, there will be loads underway soon! It will be interesting to see how you go about tackling the jig. If you just using it for the shortening process then it can be nice and simple.Comment
I wanted to be able to bolt anything to mine in any position should I want to. You could still add sill clamps to mine etc.
You could make a very simple one with 2 I beams just long enough to be under the subframe points. Then a set of holes 320mm forwards for the shortened position. If your just using it for shortening then having individual posts isn't needed you might as well make a box all welded together which picks up all 4 points at each subframe.Comment
Clive. Are you the same chap that simon andrews was talking about?
He was going on about a chap who he knows from hill climbing building a swb etc...Comment
"Unbelievably, it turns out there is another chap less than 10 miles from me who is also about to start his SQ build - albeit his will be a racer. He has an in house fab shop so I am splitting the cost of a shell shortening jig with him. Should hopefully come in useful in future if we ever build more of them."
That'll be me then. That Jeffers & Hamish have a lot to answer for!
Seasons greetings everyone!
PaulComment
Yep, that's me. Simon is a hill climbing mate - we race single seaters in the same class - this is me at Prescott in the Summer. How do know Simon? He is actually one of the people I've got lined up to do some of the work on finishing the car.
Cheers.
CAttached FilesLast edited by Clive A; 28 December 2013, 08:49.Comment
Quick update:
S2 fully stripped
80 2 door partially stripped
CQ bought but awaiting stripping
Possibility of sharing a jig
Various lights sourced
Instruments sourced
Seats sourced (but one damaged so awaiting replacement)
...and now the exciting bit...
Just ordered a full house 07k crate engine from Hank Iroz
Not much to show by way of pictures yet but will update when we have something. The slicing, splicing and dipping starts in Feb...Comment
