Project - Pete-S2
  • piotr
    • Jul 2012
    • 1470
    • Home: Poland Current: England
    #211
    • piotr
      • Jul 2012
      • 1470
      #212
      Turned it over for the first time after very long time.not sure if the link will work.after about 5 attempts,each about 5-10seconds I started to have readings on the pressure gauge.I just didn't expect it to be that high,is this normal?
        Cold idling engine will max the gauge.
        • piotr
          • Jul 2012
          • 1470
          #214
          Oh,that's ok then
          • piotr
            • Jul 2012
            • 1470
            #215
            Quick turn over with plugs
            • piotr
              • Jul 2012
              • 1470
              #216
              I have started the engine for the first time today ,and it's running on 4 cylinders
              There is nothing connected to the engine,no intercooler,pipes,maf etc etc but it still should run on 5 isn't it?
              • terrybullwon
                • Mar 2006
                • 8782
                swap injectors around and see if the dead cylinder moves, also worth doing the same with coils
                Chef
                • piotr
                  • Jul 2012
                  • 1470
                  #218
                  Cheers buddy
                  • piotr
                    • Jul 2012
                    • 1470
                    #219
                    Swapped injectors,still the same so it's not them,coils unfortunately I can't swap them.they are BERU coils and the connector sims to be bonded to the coil.Swapped plugs,no difference,and actual it's 2 front cylinders not firing
                    • Tom_
                      • Oct 2007
                      • 1301
                      • Country: Czech Republic
                      #220
                      NIce project Piotr, dimensions of oil cooler?Thank you
                      Audi Coupe Quattro 2.3 20V
                        Probably a POS unit. Try swapping them round and see if the problem moves to Cyl 4 & 5
                        • piotr
                          • Jul 2012
                          • 1470
                          #222
                          Thanks.its a 16 row 32.5cm long,15cmhigh and 5cm wide
                          • piotr
                            • Jul 2012
                            • 1470
                            #223
                            Hi buddy,did that and no difference,but I have got another set of coils from my friend and for that short period of time it was running on 5 so I think my coils are the issue.Engine is running but then it's dying-I will post link but I think it's normal as nothing is connected /no boost hoses,inter cooler etc etc.
                            • piotr
                              • Jul 2012
                              • 1470
                              #224
                              I have fitted another set of coils and engines started to run on 5 cylinders straight away-(thanks Lynn )
                              I think plan for the future about coils if all will be ok with engine is TFSIs and loom from Alex.
                              Anybody know the part number for air box grommets going in to inner wings please?
                                I think I have an airbox grommet kicking about mate
                                I can do a harness for you this week, then I am abroad for 2 weeks - drop me a PM if you need one mate : beer:
