PM send Alex
Project - Pete-S2
And one more thing-call me stupid but why there is a 2 different torque values,with audi spanner or without?what difference does it make what tool I will use?If the bolt should be torqued up to 450Nm it should make no difference what tool I will use to do it up to
I was going to fit temporarily my old down pipe and the WG flexy pipe is not lining up at all with DP.the only thing i can think off is that it's because of Wagner EM?
Any idea boys?
IMG_7377.jpgComment
The audi tool is an extension for the torque wrench, so I assume the value is lower if you use the tool as it moves the measurement point further from the centre.91 Modded 3B
14 A6 Avant Black EditionComment
This happened on mine when I swapped to RS2 spec, you can slip a piece of tube down the flexi and bend it a bit to make it work. I think you'll need to take it off and hold it in the vice, bolted to the WG
Make sure flexi is the right way round too, they make a horrible noise if they're backwards.Comment
Or if you drop the DP out the way you might be able to do it in situ ..Comment
Note misalignment
Did you fit an RS2 turbo?Comment
Cheers for the info
Good thing is I need custom made exhaust from turbo back so this will sorted bud I don't have idea where to have it done?
There is a Powerflow company in Basingstoke,anybody have any opinions about them?Comment
