My sleeper
  • diesel des
    • 3896
    #136
    Why did the rod need machine work? Was it too wide for the Honda pistons?
    Sent from my HTC Desire HD A9191 using Tapatalk 2
    • hammer
      • May 2008
      • 242
      • Country: Austria
      #137
      Yes, pistons have 24mm at the inside and Rod 25mm
      • diesel des
        • 3896
        #138
        What will the modification to the oil pump do? Reduce cavitation?
        • hammer
          • May 2008
          • 242
          • Country: Austria
          #139
          Yes.
          With this modification i can go up to ~9000rmp.
          • diesel des
            • 3896
            #140
            Originally posted by hammer
            Yes.
            Cool! Is this a stock s2 pump? What about tdi pumps can they be used? Have you done this before or where did you learn about it.
            • jsol
              • Jul 2011
              • 353
              • Country: Australia
              #141
              [QUOTE=diesel des;875804]Cool! Is this a stock s2 pump? What about tdi pumps can they be used? Have you done this before or where did you learn about it.
              Yes, very interested in this to.
              • PRY4SNO
                • 767
                Yes.
                Also interested!
                2013 Touareg TDI /// #farmenwagen
                • hammer
                  • May 2008
                  • 242
                  • Country: Austria
                  #143
                  Yes this is a tdi pump, its cheaper (130,-) and i dont ned the point for ot.
                  In germany runs a s2 with this modification up to 9000 rmp without any prob and to friends of Mine also make it so
                  • diesel des
                    • 3896
                    #144
                    This is very interesting thanks for the information. Your pictures are good but to be sure we haven't missed anything can you list exactly the work that is required to do this to the pump please. Cheers :thumbup:
                    • hammer
                      • May 2008
                      • 242
                      • Country: Austria
                      #145
                      You just have to close the oil retrun in the pump and make a hole in the block. You dont ned the pipe that i make but then you have to make the hole in an angle to the sump, that the oil can not snape the crankshaft
                      • jsol
                        • Jul 2011
                        • 353
                        #146
                        I can see what has been done to the pressure relief valve. I thought this might cause excessive oil pressure resulting in hydraulic lifters being "pumped up" and a subsequent loss of compression on specific cylinders. I presume the second part of the modification , the pipe drilled through the block draining to the sump remedies this? A few more photos or explanations would be great if you are able to Hammer. I also could be so wrong!
                        • hammer
                          • May 2008
                          • 242
                          • Country: Austria
                          #147
                          With this modification you dont get more oil pressure!
                          The pressure relief valve is the oem.
                          And you dont ned this modification when you drive hydros, because you can go over 8000rmp with them.
                          just with Solid lifters
                          Michael
                          • hiloran
                            • Mar 2010
                            • 121
                            How did you fix the electric steering column to steering rack?
                            • hammer
                              • May 2008
                              • 242
                              • Country: Austria
                              #149
                              Welded it to the original Part who is bolt-on the steering rack. But i don't have a pic of this.
                              • diesel des
                                • 3896
                                #150
                                Will even a stock unmodified tdi pump rev to 8k rpm without problems? Do you use an Audi part or another manufacture when you buy these.
