Im going to attempt to fit one of these 780x300x76mm Intercoolers.
There is various threads on here that show how they can be plumed in but i am going to try to do the piping a little different because id like to keep the Aux Rad for now
I am going to try running the Exit pipe to Boost pipe back behind the IC under the Cam Pulley and then straight up at the left. The Pipe work will look something like this:
The separate sections will be welded and the right side (IC Exit) will have another elbow welded to it so that it connects to the IC with a 60mm IDA Silicon Elbow
.I am going to try running the Exit pipe to Boost pipe back behind the IC under the Cam Pulley and then straight up at the left. The Pipe work will look something like this:
(oh well I get to go out in a 600bhp RUF GT2
