Large IC install/pluming
This is a sticky topic.
  • #31
    Looking good Bo!
    • #32
      Going to use a Evo6 intercooler on my TDI and S4 much the same as the one in this thread but a bit smaller at 500x295x70mm 60mm outlets
      Audi A6 AEL 5cyl Quattro breaking.
      Audi A5 3.0tdi Quattro Stage 2
      07947385043
      • #33
        Looking good Bo!
        Gimme a text/PM when you get this fully installed.
        My car's become a parmanent feature of the garage at the moment!
        By the way, if the rain persists and you can get the car here (somehow ) then you can use the cover of my garage.
        • #34
          Ok, have finally finished it..
          Ended up taking way longer than i originally thought because I couldn't get the Turbo to IC hose to stretch over the IC .
          Here's a few pics:
          91 S2 coupé - RIP
          98 S8 - Luxury barge
          • #35
            [ATTACH]12138[/ATTACH]
            91 S2 coupé - RIP
            • #36
              Plenty of room
              91 S2 coupé - RIP
              • #37
                Superb job, Herr Yacobs !
                Midnight Blue S2 - SOLD - 1993 S2 Avant
                • #38
                  Had to cut out two of the Grill brackets and a bit of the inside of the bumper at each end of the IC.
                  91 S2 coupé - RIP
                  • #39
                    Prima!
                    SS
                    • #40
                      Good as new!! - infact better!:mischeif:
                      Xmember diagram will be available soon, a forum member offered to convert the measurements in Cad or Auto cad so a 3D diagram should be available soon.
                      91 S2 coupé - RIP
                      • #41
                        wow!
                        Great work Bo.
                        It looks so big whitout the bumper fitted, and not so big when fitted, but all in all superb!
                        How is the performance?
                        Any noticeable, or is that only on hot summerdays that you will be feeling a diffrence?
                        EDIT: think i'll be going for some sort of the same size, so good to see that people have got that IC size fitted on the oem s2 bumper.
                        Anders - S2 Avant Clubsport - 8pots or die!
                        • #42
                          Looks excellent Bo.
                          Im amazed everytime that the std bumper fits over all of that. Did you have to cut any of the bumper internally?
                          It would like to do one about 3/4 of the height of yours to leave a gap between that and the aux rad. Might contact the seller to see if they can make some other custom sizes. Overall a 100% improvement over the standard x-member pipework and joints.
                          Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
                          • #43
                            Cheers Guys,
                            Yeah quite a noticeable difference in pick up and spooling. Seems to boost a fair bit faster and more steady too..
                            Before i used to get quite a bit of fluctuation and the boost gauge needle bounced around all over the shot until it hit 1.4bar.
                            Now it goes up Fast ans smoove "cough cough"
                            but doest peak quite so high.
                            I used to get 1.4 - 1.45 bar and now its peaking at about 1.35
                            I think the IC is to big for the K24 - good thing that i'f got a K26 on the way
                            Yeah i had to trim the inside of the bumper a little bit and took off the two brackets that hold each end of the center grill. (they are not need though - there's two more brackets that hold that grill in place so its fine with out them)
                            This pic shows a little bit better what was taken off.
                            Baring in mid that i didn't take any measurements and just sized up the bites that had to be trimmed step by step.
                            91 S2 coupé - RIP
                            • #44
                              Excellent Bo, that was quite a mission!
                              • #45
                                looks spot on bo
                                1. SHORT SHIFT KIT
                                2. PORSCHE CAYENNE CALIPERS
                                3. H & R SPRINGS
                                4. BILSTEIN SHOXS
                                5. NEW BUSHES AND HP2 STRUTS
                                6. UPRATED HIGH OUTPUT COIL PACK
                                7. ,3" turbo back s/s/ exhaust
                                8. fmic fitted
