Originally posted by newsh
View Post
Large IC install/pluming
This is a sticky topic.
Here we go
S2 Aircon and ur alternator bracket snubmounts, the ur one is shorter but the S2 Aircon one is much stonger.Attached Files
AnotherAttached Files
The solution, the spigot basically moves its own diameter down the line between the two bolts. These are bridged with a piece of seriously strong alloy bar. There is also the option to bridge all three bolt holes with a triangular plate and weld or bolt the spigot to that. I'll see how this works out first.
Now just waiting for a few more bits of pipe to arrive..Attached Files
Nearly done, just a small issue with the alternator belt adjusterAttached Files
Looking superb mateJim B
97 S6 AAN Quattro Avant C4 | Powerflow Cat Back EX | Milltek Hyperboost RV | MAC N75 Valve | FMIC | HID's (Dip & Fog's)| MRC Re-map SII | Carbon interior | De-chromed | Short shift | Samco Air Hoses |
http://smogthemog.blogspot.com/
Originally posted by s2_bo View PostSo close! Hope you mange to get it sorted with out to much trouble modding.
Your alternator must be sitting slightly higher than mine.. :S
Unfortunately the battery is flat
Did you know your BHP and Torque figures before you started this project?Jim B
Originally posted by smogthemog View PostDid you know your BHP and Torque figures before you started this project?
Originally posted by PapVas View Postfor all you guys with the aux rad taken off,what are the differences in engine temps in various situations?
I guess you would know you are in trouble when the fan stays on and the temperature keeps rising.
You could always try running without the aux rad without removing it. Just take of both of the hoses running into it and bung them.
I used 22mm copper end caps in mine, placed with the top of the caps inside the hoses, so it looks like the hoses are open, which has caught a few people out.
Good work there Mr Newsh. What was the issue with the alternator belt adjuster?SS
Shurely it would have been better to join the two pipes together so the water flow continued rather that just bunging up the endsJim B
