Quick 'how to' replace fuel lines
This is a sticky topic.
Mine look worse than Steve's... but only just started leaking last week.Paul Nugent
My worst fear is one of them suddenly splitting and pissing petrol at pressure on to the neighbouring hot stainless steel exhaust. I think the car would be a fire about in about 2 minutes!
The Perfectionist
Attached are the Wade instructions...The Perfectionist
Do we really need to worry about using these WADE connectors - are they so much better than generic / noname fittings ?
There is a liquid PTFE sealant available from FROSTS that is designed to make such connections more robust. Often used on air line fittings on trucks I believe.
As to fuel line bursting - tis a worry but I remember a thing on TG years ago where I think it was Tiff who did a test to camera by spraying various liquids onto a hot exhaust manifold. Petrol didn't ignite - but brake fluid went up in a great burst of flame.Paul Nugent
At 1.90 each I figure they are not THAT expensive. I have just spent about ÂŁ80 on rust preventer and paint!
Also they look like they will be easy to fit and then forget.
I will let you know how I get on with these next week...
The Perfectionist
Its not the cost here - just the fuss factor about WADE...Paul Nugent
As the person who started the 'Wade' requirement
I think I should just say, I'm sure it wont matter if you use an alternative, but all I know is that they were the ones recomended by a trusted supplier of mine and I can vouch for their quality.
Last thing you want is to put a duff connector on that not only leaks but knackers your nice, new & straight piping because you have to fit another bit!sigpicComment
/\ /\ /\ /\ And a big thank you to the OP for starting this thread. It made a daunting job look a lot lot easier.
The Perfectionist
