So I have been wanting to build a stroker for a long time for my urs4 and also my urq. I started gathering up parts for the last few years and started the build on 1 engine for my daily urs4. When I say daily, what I mean is I drive it at the weekends mostly and sometimes during the week. It does 7 to 10 K miles per year. I drive a van/jeep during the week for work. The urs4 runs on lpg autogas and has a stock ish engine with a garrett Gtx2867r on a rs2 manifold, 630cc petrol injectors, 3 inch exhaust, 600 x 300 x 75 mm intercooler and vems for an ecu. It has a South bend clutch and a v8 s4 gearbox at the moment which is noisy.
Want I want is a engine that makes more low down grunt. I'm not looking for big top end bhp numbers. The idea was a bigger capacity engine and a small ish turbo is the way forward for a fun car to drive. If I'm making mid 4xx bhp then the car will be plenty fast enough. If I come up against something that pulls out and leaves this on the motorway, then I would need something like 600 bhp to stick with it, and I couldn't drive that sort of compromise in a urs4 as a daily. But the Urq build will be different
Anyhow I got a 140bhp tdi engine ael I think and used that as a donor. I was trying not to spend a fortune so the plan was to use as many stock non custom parts.
So I will post a few pictures next.
Sent from my GT-N7105 using Tapatalk
