A bit better spool, but exactly the same power at the same boost (stated by the person who produced the graph). So the turbine does not flow any better.
As for holset… HX35S spool on bone standard 2.2T with a fairly quick ramp rate, full boost is at about 4k here. This is just a bit quicker ramp rate than with 3rd gear on the road. Power and torque is at the wheels, so 600nm at 4000 rpm, and 645nm peak, and power is about 550hp, but WMI helps a little here
If you compare quattro-nick's result on the same type of dyno:
The turbos spool in a similar way, the HX35S comes in a bit earlier (550nm vs 600nm @ 4000 rpm). The power figures is hard to compare without knowing the correction factor on the dyno used by quattro-nick, as the superflow here only gives wheel power.
It is instant.As it is in your octavia 3 rs 2.0.
