S6 timing
    replied
    Originally posted by HMS-S6
    When this car is running, occasionally there is a fuel smell around the right rear wheel. So far id dismissed this for being linked as id wrongly fixated on a timing issue up till recently.
    Could be a number things, e.g. rusted tank leaking, Item 5 leaking, overflow hose (not shown)..
  • HMS-S6
    replied
    Hmmmmmm. Interesting reading! Think I'll be having the top back off the tank next week then. When this car is running, occasionally there is a fuel smell around the right rear wheel. So far id dismissed this for being linked as id wrongly fixated on a timing issue up till recently.
    replied
    so I can't see this is possible on an S6??
    Cavitation is one possibility if the inlet gets clogged. The sucking of the pump across the clogged screen could lower the pressure on the back side of the screen to the point that vapour pressure is reached and bubbles form.
    "Cavitation is the formation of vapour cavities in a liquid – i.e. small liquid-cavitation-free zones ("bubbles" or "voids") – that are the consequence of cavitational forces acting upon the cavitational liquid"
  • HMS-S6
    replied
    I have driven the car with the gauge resting on the screen so I can read it but I'm still going to take a look inside there. I have had it on another car where it was drawing air so although it had pressure I was a fuel/air mix, but this car WASN'T a submerged pump so I can't see this is possible on an S6??
    replied
    Just running an idea! Even with pressure AND flow, is it possible to still have a fuel delivery problem?
    Certainly. It could be a pump or a pump inlet clogging issue *OR* it could be a kinked fuel line. Who knows.
    What you could do is at least check the fuel pump for debris (rust) around the inlet. Maybe in motion, the tank has debris that gets stirred up and sucked onto the inlet screen, limiting flow into and out of the pump. Something that doesn't show up during a static fuel pump test.
    You could use this 19 page pdf that I wrote regarding C4 fuel pump testing and replacement as a guide:
  • HMS-S6
    replied
  • HMS-S6
    replied
    Thank you.
    replied
    AAN boost leak testing options
    It was entering the cam cover via the breather when testing the MAF hose. I was doing it wrong!
    Previously posted:
  • HMS-S6
    replied
  • twoqu
    replied
    The only other thing that was bothering me was the air escaping from the oil filler cap when pressure testing but not entirely sure why!
  • HMS-S6
    replied
    My friend (ex-boss) has an asnu and is back in 3 weeks so can check injectors then (even though they've been substituted off my good car once). But yes, despite good flow and pressure it can't hurt to remove the pump basket to look for anything obvious.
    Also tomorrow I will triple check the throttle switch but last time I had vag-com attached, it was showing 99% at WOT.
    And no, thanks, it's nice to have a second brain to bounce ideas off!
  • twoqu
    replied
    Yep! The boost signal for the in dash gauge comes out of the ecu so it must be seing it!
    Seems reasonable to compare similiar cars. As you say if the ecu is requesting the right amount of fuel but not getting it, what else could it be other than the injectors now. Other than voltage which the ecu can make adjustments for and earth, the only other thing is perhaps blocked filter baskets or an actual detioration in the windings.
    Sorry I can only offer stupid ideas and some support!
  • HMS-S6
    replied
    We are on exactly the same thought!! I agree 100% that the car isn't fueling to match its boost but until I know what duty cycle ROUGHLY other stock cars are showing in my trouble spot I don't know if it's not TRYING to richening up or its trying and CAN'T. See what I mean or an I just lost in my own mind? Lol
  • twoqu
    replied
    Of course what we are calling excess air might be the boost! Its almost like the ecu is not seing the boost and therefore not making any adjustment. Then again I am not sure the map sensor has anything to do with fueling as thats the reason for the two boards! The demand for the air is measured by the maf. The more it sucks in the more fuel it adds, oversimplifying it somewhat!
    The low 14 afr is almost like a cruise figure. Be useful to calculate what the ratio between what you should have and what you are getting represents in terms of fuel requirement. Sounds like a considerable amount.
  • HMS-S6
    replied
    I know!! Annoying as its defying logic at the minute. I upped the fuel pressure the other night and it richened it up AND improved running which kinda proves the symptoms but obviously I shouldn't need to do this for standard SW! Very odd.
