Any interest it C4 adjustable camber/caster plates?
    Originally posted by Thuppu
    I understand. It would need a totally different style plate with the stock top bearings and rubber bushings, but I will look into it, I may have an idea of how to do it. These spherical bearing plates will always be noisy, at least when the bearing get some play in it.
    Grand, thanks, enjoy your threads / posts.
    • Thuppu
      • 4115
      The motorsport versions have 43mm adjusment. Hope they fit in place...
      Already made a DXF of the camberplates that fit stock top mount bearings and bushes, can only get 14mm adjustment on them. Of course also the big stock spring is limiting the amount of the adjustment so 14mm can be fine.
      • diesel des
        • 3896
        Do you know what 14mm adjustment gives in terms of extra castor?
        • Thuppu
          • 4115
          No, I don't know. It may be pointless to make plates for the stock top, as the adjustment on the stock parts is propably close to the same. The size of the top bushing is so big, also the bearing construction needs attention as it's under the plate. Quite difficult to make it work with more adjustment.
          • Thuppu
            • 4115
            Seems to fit in place nicely. Only change I have to do is to move the camber adjustment bolts closer to each other. Now they limit the movement a bit.
            • s0_big
              • Dec 2009
              • 685
              Nice
              Wery nice pieces
              • Thuppu
                • 4115
                A small improvement to get the full adjustment in use. Didn't wan't to change the main plate, because it would go weaker if it don't have the notches between the adjustment holes.
                A vid of the first version, without the extra threaded holes:
                • Thuppu
                  • 4115
                  Last important part made up for the camber plates. Small bushings to get a proper fitment between the shock and the bearing. This work with at least Bilstein and Koni shocks, propably with others also.
                  • diesel des
                    • 3896
                    #24
                    Lookin good!
                    • michaels2s
                      • Nov 2012
                      • 87
                      What is the price of a pair?
                      Iam interested,looking nice
                      [__]=oooo=[__]
                      • Thuppu
                        • 4115
                        One pair is 220 euros + shipping. Hope to get pictures of a finished kit tomorrow.
                        • Thuppu
                          • 4115
                          First pair ships out to USA. Hope everything works good because I havn't bee able to test these yet.
                          • ringbearer
                            • Sep 2011
                            • 176
                            Looking good!
                            Nice to have another option
                            • Thuppu
                              • 4115
                              Thanks! These will ad a lot more adjustment range than 2B, propably some like 20-25mm more.
                              • petro238
                                • Feb 2009
                                • 20
                                • Country: Italy
                                #30
                                nice set!
                                ..I could do with one... it would be a nice christmas present for my car!
                                ..any more available?
                                Thank you
                                P.
