QUOTE=dan_b]@Robo, have you fitted it yet? Any thoughts on it? Have you changed the front as well?[/QUOTE]
Dan I will be fitting it in 2-3 moths time, I am in the process of striping everything of the car and ordering lots of parts.
I will not be able to tell you of any improvements cos I only drove the car for 2 miles as standard.
Originally posted by dan_b
) and had to cut off the weakest setting to make it fit. Uses the new strongest setting on dry tarmac and car is neutral handling with oversteer on "lift off"(let go of throttle). Uses the weakest setting in the wet, and removes the bar in winter/snow conditions. Set on hardest on snow makes car very "tailhappy" if you let off into a corner. Have to drive it like a Porshce: easy into the corner and apply power through corner
Now where did I put my toolkit...
