Whiteline rear ARB
This is a sticky topic.
  • robo
    • Aug 2004
    • 2086
    • Home: Poland Current: England
    #241
    QUOTE=dan_b]@Robo, have you fitted it yet? Any thoughts on it? Have you changed the front as well?[/QUOTE]
    Dan I will be fitting it in 2-3 moths time, I am in the process of striping everything of the car and ordering lots of parts.
    Originally posted by dan_b
    Any thoughts on it?
    I will not be able to tell you of any improvements cos I only drove the car for 2 miles as standard.
    sigpic_________
    Rob
    • Ski
      • 2591
      #242
      Very good idea!!
      isnt it a PITA to change settings everytime it rains?
      Originally posted by Audi_CQ
      I drilled another hole in it(stronger then strongest ) and had to cut off the weakest setting to make it fit. Uses the new strongest setting on dry tarmac and car is neutral handling with oversteer on "lift off"(let go of throttle). Uses the weakest setting in the wet, and removes the bar in winter/snow conditions. Set on hardest on snow makes car very "tailhappy" if you let off into a corner. Have to drive it like a Porshce: easy into the corner and apply power through corner
      Cheers,
      Roger
      ABY Coupe
      • Albert
        • 1500
        • Country: Poland
        #243
        Can some one veryfy is the RS2 FARB is 28 mm ?
        AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
        • mcandmar
          • Apr 2004
          • 5118
          Yep 26mm S2, 28mm RS2. 15mm rear on coupes.
          91CQ20v - Gone to a new home
          93UR-S4 - The Magic Carpet
          94S2Bus - The Emerald Express
          • Azman
            • 3205
            Joining the gang, Ordering a RS2 FARB today, Whiteline Rear will have to wait until next month, Or do you think I should order them the other way round????
            Dark Grey Avant
            RS2 FARB
            Alloy Subframe Bushes
            • Paulgo
              • Jan 2005
              • 498
              Just out of curiousity, anyone know if the ARB's on a cq20v are the same thickness as an S2??
              cheers
              Paul
              Trick Pearl White 1992 3B S2 Coupe. Porsche 996 monoblock stopping power! HID Seeing power! Mmmmm Miltek!!!
              Trick Indigo Pearl B5 S4 Recaros, Bose , Mmmm Miltek!!!
              • mcandmar
                • Apr 2004
                • 5118
                Yep CQ20v and S2 are the same, pre 1990's dont have a rear bar, post 90 do.
                • Ski
                  • 2591
                  #248
                  Azman get the rear first
                  ABY Coupe
                    Both are hard to get hold of but order the Rear first as it takes an age to get them. QRS had some stock of them though
                    • BRY
                      • 3755
                      #250
                      The fronts are easy to get hold of :mischeif:
                      • Chris5044
                        • Feb 2005
                        • 1663
                        me doing this as soon as the bank permits
                          Well yes if you've got a front room full of them
                          • BRY
                            • 3755
                            #253
                            I have made room in the garage
                              Lol that will keep your mrs happy
                              • Ross
                                • Aug 2005
                                • 3399
                                Oh what a beautiful morning...
                                Well, the sun is shining, I'm chilling on the couch watching TV and just abouts to chow down some Crunchy Nut Cornflakes. How could it get better??
                                Well, a bloke knocked on my door and asked 'is this yours?' with a big box that says "whiteline sway bars" on it
                                I'm gonna go get my grubbies on - only one question, which hole? The tightest one I'm guessing? Now where did I put my toolkit...
                                Ross
