Propshaft Overhaul
  • Skull
    • 3506
    • Country: Slovenia
    #166
    Great! How much does it cost?
    With your kgn part number, i was able to find the original Löbro part number, which is U741.
    Audi Quattro WR
    • Holla
      • May 2007
      • 57
      • Home: Norway
      #167
      think i paid around £60-80 or something like that... but that's in Norway
      great! Dont know if Löbro exists as a company still though.
      • Snow Racer
        • Feb 2010
        • 12
        • Home: Estonia Current: Norway
        #168
        where i can I buy the GKN or Löbro u-joint?
        • Skull
          • 3506
          • Country: Slovenia
          #169
          I couldn't find them, i could only get a suzuki part (from a vitara), manufacturer is Ashika, part number 66-08-803.
          I didnt install it yet, but it should fit, the measures are right.
          Audi Quattro WR
          • saltinot
            • May 2004
            • 1946
            #170
            What should the measurements be?
            • Skull
              • 3506
              • Country: Slovenia
              #171
              LENGHT: 2.756"
              BEARING CAP DIAMETER: 1.024"
              or 70x26mm
              Audi Quattro WR
              • Holla
                • May 2007
                • 57
                • Home: Norway
                #172
                • Holla
                  • May 2007
                  • 57
                  • Home: Norway
                  #173
                  btw.. https://www.powertrainindustries.com...m?type=UJoints
                  Check partnumber 2551-26
                  • Horsty
                    • Oct 2011
                    • 94
                    there is a bearing available here:
                    audi100.net
                    Audi Coupé Quattro 20V
                      #175
                      Just read this thread through.
                      I have a urS6 with a noisy and worn CV joint before the diff. It has no boot on the CV joint ?
                      I would like to know if I can just undo the six bolts that connect the rear CV joint to the propshaft, allow the rear of the propshaft and CV joint to drop down bit, remove the circlip and either tap off the rear CV joint, or use a pullers to get the CV joint off, and then fit a new Lobro or Febi CV joint ?
                      Will it be as easy as that, or am I missing something ? Comments from people who've tackled this job recently would be ideal.
                      For the people who've done it recently, what part number CV joint did you use for the rear CV joint ?
                      As a matter of interest, are the front and rear CV joint part numbers the same ?
                      Should both the front and rear CV joints be fitted with a normal CV boot, or did they both come from the factory without a boot ?
                      Thanks for any input.
                        #176
                        to the top.
                        • tomwood_uk
                          • Feb 2009
                          • 336
                          http://www.ebay.co.uk/itm/FORD-SCORP...item1e651b6fce
                          Can anyone confirm that the above Ford Scorpio C.V joint is the correct part?
                          • goodall
                            • Jul 2008
                            • 810
                            #178
                            GKN (lobro) joints and boots are available from demon tweets
                            Boots
                            http://www.demon-tweeks.co.uk/motors...-cv-joint-boot
                            Dia 99 PCD86
                            CV
                            There are also lightweight version available...
                            http://www.demon-tweeks.co.uk/motors.../gkn-cv-joints
                            Option 4
                            PN 301142
                            I got a new Cross for the centre UJ on eBay
                            http://www.ebay.co.uk/itm/3313090051...%3AMEBIDX%3AIT
                            Its part number from GWB (Dana Spicer), 287.00
                            Or
                            GKN, 12111
                            Lobro, U741
                              Thread resurrection service.
                              SKF VKJA 8688
                              LOBRO 301142 Analogous Parts
                              Part Numbers matching the Loebro number. Check the dims but HTH:
                              ALFA ROMEO 0004315132 Joint Kit, drive shaft
                              ALFA ROMEO 0009936769 Joint Kit, drive shaft
                              ALFA ROMEO 0060806930 Joint Kit, drive shaft
                              ALFA ROMEO 0082282139 Joint Kit, drive shaft
                              ALFA ROMEO 0092601388 Joint Kit, drive shaft
                              ALFA ROMEO 0092601892 Joint Kit, drive shaft
                              ALFA ROMEO 4315132 Joint Kit, drive shaft
                              ALFA ROMEO 46307129 Joint Kit, drive shaft
                              ALFAROME/FIAT/LANCI 4315132 Joint, drive shaft
                              AUTEX 823244 Joint Kit, drive shaft
                              BUGIAD 50802 Joint Kit, drive shaft
                              BUGIAD 51147 Joint Kit, drive shaft
                              CAR GFR8220K Joint Kit, drive shaft
                              CIFAM 617-005 Joint Kit, drive shaft
                              DELCO REMY DRC09012 Joint, drive shaft
                              DELCO REMY DRC09012K Joint, drive shaft
                              EKG 920439 Joint, drive shaft
                              EKG 921561 Joint Kit, drive shaft
                              FARCOM 134142 Joint Kit, drive shaft
                              FARCOM 240236 Joint Kit, drive shaft
                              FIAT 0001493963 Joint Kit, drive shaft
                              FIAT 0004315132 Joint Kit, drive shaft
                              FIAT 0009936769 Joint Kit, drive shaft
                              FIAT 0046307129 Joint Kit, drive shaft
                              FIAT 0082282139 Joint Kit, drive shaft
                              FIAT 0092601388 Joint Kit, drive shaft
                              FIAT 0092601892 Joint Kit, drive shaft
                              FIAT 1493963 Joint Kit, drive shaft
                              FIAT 42601388 Joint Kit, drive shaft
                              FIAT 42601892 Joint Kit, drive shaft
                              FIAT 4315132 Joint Kit, drive shaft
                              FIAT 46307129 Joint Kit, drive shaft
                              FORD 1493963 Joint Kit, drive shaft
                              FORD 4315132 Joint Kit, drive shaft
                              GENERAL RICAMBI FI2001 Joint, drive shaft
                              GSP 602006 Joint Kit, drive shaft
                              GSP 618001 Joint Kit, drive shaft
                              HOLDEN 153120188003 Joint Kit, drive shaft
                              IPD 32-2239 Joint Kit, drive shaft
                              KAGER 13-1031 Joint Kit, drive shaft
                              KAMOKA 9024 Joint Kit, drive shaft
                              LANCIA 0004315132 Joint Kit, drive shaft
                              LANCIA 0009936769 Joint Kit, drive shaft
                              LANCIA 0046307129 Joint Kit, drive shaft
                              LANCIA 0082282139 Joint Kit, drive shaft
                              LANCIA 0092601388 Joint Kit, drive shaft
                              LANCIA 0092601892 Joint Kit, drive shaft
                              LANCIA 42601388 Joint Kit, drive shaft
                              LANCIA 42601892 Joint Kit, drive shaft
                              LANCIA 4315132 Joint Kit, drive shaft
                              LANCIA 46307129 Joint Kit, drive shaft
                              LEMFORDER 19142 Central Joint, A-frame arm
                              LOBRO 302238 Joint Kit, drive shaft
                              LPR KAR801 Joint Kit, drive shaft
                              LYNXAUTO CI-1006 Joint Kit, drive shaft
                              MAPCO 16056 Joint Kit, drive shaft
                              MAXGEAR 49-0370 Joint Kit, drive shaft
                              METELLI 16-1005 Joint Kit, drive shaft
                              ODM-MULTIPARTS 14-016037 Joint Kit, drive shaft
                              OPEN PARTS CVJ5399.20 Joint Kit, drive shaft
                              PATRON PCV1005 Joint Kit, drive shaft
                              PEX 10.201 Joint, drive shaft
                              PROFIT 2810-1005 Joint Kit, drive shaft
                              PROTECHNIC PRJ529 Joint Kit, drive shaft
                              PROTECHNIC PRJ536 Joint Kit, drive shaft
                              RUVILLE 75251 Joint, drive shaft
                              RUVILLE 75251S Joint Kit, drive shaft
                              SHAFTEC PJ11N Joint, drive shaft
                              SKF VKJA 8688 Joint Kit, drive shaft
                              SPIDAN 20439 Joint, drive shaft
                              SPIDAN 21561 Joint Kit, drive shaft
                              STELLOX 160 1005-SX Joint Kit, drive shaft
                              TRISCAN 8540 16004 Joint Kit, drive shaft
                              VEMA 18042 Joint Kit, drive shaft
                              • RAOUL
                                • Sep 2003
                                • 260
                                Hi. Has anyone managed to find/source the centre universal joint for the prop? I have a new 034 Centre bearing (courtesy of Edward @ WOT Motorsport) & 2 new CV joints for the ends. I'm drawing a blank on the UJ though? Any help much appreciated. 🍻👍🏻😊😎
                                ATB
                                RAOUL
