English please folks
Project 450 - Will it be enough!
No need I can translate; We love pölse, we are red and white, and we all suck at Icehockey, Sweden has the best Audibuilders..
That's pretty much it
2004 9-5 aero
2009 Subaru Legacy Diesel
1994 Toyota Supra Eurospec 6-spd LHD
3-4 Audis in parts
your mad ,don´t finish one thing before you start another,happy with your choice off charger since iam kkk fandu er tossig når ikke at blive færdig med den ene ting inden du skifter igen,er glad for dit valg af lader er jo selv kkk fan too(and that´s the turbo not the reed neks in the us)
vi må snart finde en dag til at mødes,hvad med rs2 knaster og portet top,når nu du er igang
vil nok sætte nye ringe i da den bliver skilt helt ad og husk at tjekke oliepumpen,lad den ligge badet i olie ellers er den færdig når du samler igen.
Vh.
we must soon find a day where we can meet,how about rs2 cams,and a port/3 angel valve job when your ad it.
i would put new (piston rings)rings in now that it´s totaly apart,remeber too check the oilpumpe,please leave it in a bath off olie other wise i could be dead when you assemble it again.
is that good inough for you guy´s
i my self have no problem with the language being,german,brittish,norsk eller svensk and off course danish
the problem with you sweeds are you don´t wont too understand danish
I dont think I will be using RS2 CAMs or 7A for that matter. With the small 6" exhaust housing I dont think it will be good for spool or EGT'sComment
@Bram
Good to know, thought they where more alike.Comment
Don't think I will go with reverse inlet, to much hassle and then it would look stock at all
Some new parts arrived today:
Rods from Aronmatic
Nice little alarm that blinks and makes a sound from Zeitronix. You can set it up with different restrictions like:
boost greater then 26 PSI.
EGT greater then then 780 Celcius
AFR greather then 12.5 and RPM greater then 4000 and WOT = 100%
When it is trigger I will wire it up so that the Eboost lowers the boost to spring pressure.
@Steve
I have the tripple gauge pod in the center vents. So I removed the VDO EGT gauge that I had since I did not need it after I switched over to a Zeitronix EGT probe instead. And the I fitted the Eboost2 gauge in the tripple pod.Comment
More things installed
I was on holiday in the US for three weekend and I just happend to buy a few things from summitracing and 034motorsport
Got the C4 fuel pump relay kit, and most say that it is worth every penny and very easy to install. And for only 45$ it is great value as well. Linky
As mentioned in the previous post I have now installed the Zeitronix trigger/alarm system and it works really well. Sofar I have only made to simple rules, but when they get triggered it activates the Eboost2 by earthing one of it inputs. Thereby it will shift to a different boost group that only runs spring pressure as longs as the alarm is activated.
I used the relay to power my Eboost2 output, this will control a solenoid. The solenoid valve will activate the 3" exhaust cutoff vale valve. The eboost2 will open the exhaust cutoff valve over 4000 RPM and over 1.1bar of pressure.
I bought this exhaust cutoff from QTP:
I will drop the electric motor and use a actuator from a VW TDI instead.
I will post some video and pictures next week.Comment
