struikie - Audi 80 B4 quattro project
  • struikie
    • May 2019
    • 314
    Put the rear fender liners in place today.
    How are you guys preloading the suspension and still access the bolts?
    JW
    | project | 1993 Audi 80 VR6 turbo quattro |
    | daily | 2018 BMW G31 530d | 345bhp 770Nm |
    • Antsa
      • Nov 2016
      • 611
      I usally take note of the distance between wheel hub center and the edge of the fender. Then just put a jack under the lower suspension arm and load the suspension so that the distance between the hub and fender match. Then tighten the bolts.
      • struikie
        • May 2019
        • 314
        Thanks!
        I can lower the ramp with something supporting the lower arm.
        The KW suspension manual has some measurements for reference.
        JW
        • struikie
          • May 2019
          • 314
          Drive shafts in place with new gaskets.
          Exhaust in place (pfff difficult and heavy on your own).
          Going to find some different 3" clamps. Really don't like these ones.
          I think I get the missing brake hoses this week. This Friday I'll put them in place
          and bleed the system. After that I'll do an alignment by sight. Booked an
          alignment job for Friday next week.
          First time on it's wheels since September last year.... feels really good!!
          Set the height to the max specified by KW.
          Front: 340mm from the center of the wheel to the fender arch.
          Rear: 330mm.
          It will drop a bit in time.
          After I had done the exhaust I could have it running a bit to check the fuel lines again
          and verify the fuel pressure. It was already set to 4 bars by Nuke Performance.
          JW
          • struikie
            • May 2019
            • 314
            Last Friday I put the heat shields, drive shafts and exhaust back on.
            Supported the suspension to tighten the bolts at ride height, bled the brakes and took it
            for a very short spin. Had to bleed the brakes again....
            Washed her this evening.
            Paint looks alright, until you get up close... it's terrible...
            Have an appointment for an alignment this Friday.
            The exhaust is leaking at the conical rings at both cats. Can't seem to
            get that fixed. Think I'll ask the garage that does to alignment to have a go.
            Ordered the stainless mesh type donuts to see if I can get it to seal
            with those.
            JW
            • struikie
              • May 2019
              • 314
              Well, I got stranded today.
              Couple of miles from the office I heard a noise like something was flapping around
              in the engine bay. The noise went away and all seemed fine, until a bit further
              up the road the engine temp was rising quickly.
              Stopped the car and it was very hot with coolant over flowing and there was a
              strong burning rubber smell. I am guessing the water pump has seized because
              the belt is still on. There is a rattling noise when I try to start the car.
              Engine still ran OK before I stopped.
              My dad towed me home. I'll have to investigate when I have the time....
              A car with quattro is a bitch to push around !
              JW
              • RedV6
                • Jun 2026
                • 64
                Bummer. Fingers crossed it's something simple and no harm done.
                • 89 Coupe
                  • Aug 2016
                  • 125
                  • Country: New Zealand
                  #263
                  Originally posted by struikie
                  Happy that I managed to snag a correct under body tray.
                  JW
                  Hello mate,
                  Are you please able to tell me the part number for the correct under-tray for the S2 Bumper?
                  I am looking for one for my 80 Avant with S2 front.
                  Ps, it looks spectacular under there!
                  Cheers!
                  • struikie
                    • May 2019
                    • 314
                    Originally posted by 89 Coupe
                    Hello mate,
                    Cheers!
                    Thanks!
                    This is where I bought it. They still have one.
                    Zustand: Gebraucht mit Gebrauchsspuren in Form von Verunreinigungen/ kleinen Kratzern möglich. Die Ware wird ungereinigt geliefert. Die Ware wurde geprüft und ist funktionstüchtig!
                    JW
                    • struikie
                      • May 2019
                      • 314
                      Water pump feels bad and the pulley is seized and out of place.
                      The timing is still OK, but the belt is loose. I hope I was lucky.
                      JW
                      • struikie
                        • May 2019
                        • 314
                        Fitted a new cam belt, roller and tensioner and a new poly belt + tensioner.
                        Started the car and it ran fine, so no damage to the engine.
                        I do have a major oil leak at the front of the engine. I think the gasket
                        of the oil pump has failed.
                        Anyone have some tips and tricks on replacing that?
                        Removing the lower sump to access the bolts from below and removing
                        the bolts from the front should be doable...
                        JW
                        • RedV6
                          • Jun 2026
                          • 64
                          Wow. The sun was definitely shining on you there. 90mph on a motorway would have been a whole different story! ?
                          • Henkjan
                            • 1705
                            that is a relief
                            • struikie
                              • May 2019
                              • 314
                              Very much a relief indeed!
                              Car is now running again. Oil leak fixed. I suspect it was a loose bolt all along
                              because it was always leaking. When removing the oil pump, one bolt was
                              very loose....
                              Replaced the oil pump gasket, the front main seal and the oil pan gasket.
                              Also replaced the cam and crank sensor to fix a rough idle, but no
                              such luck. These ECU's aren't the most reliable so bought one to test.
                              The allen socket on the top bolt for the oil pump was rounded by a previous
                              owner, so had to buy a new one from Tradition. As the shipping cost are high
                              also ordered some trim I will need in the future, like the lower front grilles, rear
                              license plate holder and the upper door trim. Fitted a new crank bolt.
                              Replaced the temporary stock brake hose to the rear calipers with the
                              Goodridge lines in the correct length.
                              Fixed the sunroof guide by 3d printing the plastic piece that is no longer available.
                              The PETG material is a bit too brittle, so will try TPU. If that has too much resistance,
                              I'll try ASA.
                              JW
                              • RedV6
                                • Jun 2026
                                • 64
                                Wow. Good work and a great feeling being able to tick off those little annoying jobs.
