My Coupe project
  • Bowie69
    • Nov 2013
    • 2675
    New SKF joints on the front, or just refurb?
      • Dec 2017
      • 5987
      All the joints feel good so wash out, new grease and boots.
      • sidrick
        • Jan 2011
        • 1342
        Excellent graft, as ever!
          • Dec 2017
          • 5987
          I’m using my parts washer to get the worst of the grease out. It says your not meant to use solvents in it but I don’t like water based de greaser, especially for parts that need to be kept dry. I’m using heating oil. It works really well and is relatively cheap. So far the pump hasn’t died.
          Then lots of nice clean rags and carefully take apart/clean noting which way the cage and inner race fit.
          New grease and boot not forgetting the cup washers.
          One down, seven to go.
            • Dec 2017
            • 5987
            I found a strap wrench handy for torquing up the prop shaft bolts.
              • Dec 2017
              • 5987
              I couldn’t resist fitting my first assembled drive shaft.
                • Dec 2017
                • 5987
                I finished all the driveshafts today.
                One tip which makes it easier to get the new boot on is to wrap the end in insulating tape.
                Last one to be done.
                Now the heat shield on my downpipe is missing. I got some exhaust wrap to take its place. I was thinking of fitting my RS2 downpipe that I have spare but maybe will at a later date.
                Front subframe also went up without any issues.
                You can clearly see the old bush marks which makes alignment easy.
                • SteveH
                  • 4460
                  91 Modded 3B
                  14 A6 Avant Black Edition
                  • s2driveruk
                    • 12696
                    Looking really tidy in there!
                    1992 3b S2 Coupe
                      • Dec 2017
                      • 5987
                      Thanks guys. I appreciate your support.
                      I made up some new splash guards from an old piece of tractor inner tube. It’s the perfect thickness and very similar to the original material.
                      I used a soldering iron to make the holes. It’s impossible to drill. I suppose you could use a hole punch as well.
                      Just a few little jobs to tidy up then I can start rebuilding the front end.
                      • Bowie69
                        • Nov 2013
                        • 2675
                        I have some left over EPDM membrane from doing a roof recently, I think I will be doing the same as mine are ruined on one side!
                        • fish
                          • Aug 2007
                          • 2333
                          • Home: United Kingdom Current: Sweden
                          #327
                          Loving the updates Dave! What happend to your Urquattro? On the backburner or moved her on?
                          Audi 80 Competition -94 Daily driver
                          www.garaget.org/fish for more pic´s of my cars
                            • Dec 2017
                            • 5987
                            It's a long story but it's still in the paint shop. 16 months now! I have been promised it will be done by mid March. We will see
                            • fish
                              • Aug 2007
                              • 2333
                              #329
                              Flipping heck, and here i am pissed for waiting a week on an estimate for painting my boot lid for my A4 allroad, haha.
                                • Dec 2017
                                • 5987
                                No power for the last two days after the storm hit so progress has been slow.
                                My wing closure panels were missing. The car has had new front wings at some point and obviously the body shop that did them didn’t think they were necessary.
                                Thanks to Mark Midge for sending me a nice pair.
                                And fitted. Not easy with wings on!
                                Next job was to re fit the gearbox mount covers. I used stainless fittings.
                                Then the steering rods.
                                Both adjusters are seized and one ball joint had to be cut.
                                I undid these bolts and removed the whole assembly through the nearside arch. The damper seems good as is the gaiter.
                                Removing the ball joints and adjusters was a vice and blow torch job.
                                Then re fitted with new adjusters and ball joints. The adjusters are SKF and the joints Lemforder.
                                After a clean down they received some zinc paint. My cat kept an eye on them for me during the cure process.
                                They will receive some satin black tomorrow.
