A little something to keep me busy
  • fish
    • Aug 2007
    • 2333
    #31
    Originally posted by martinjs
    HP2 brakes are pretty good IMO, I don’t see much benefit fitting 996 callipers, completely different lug design anyway, yes US cars had G60’s I believe.
    How come a lot of the US models of sportier cars always had something 5h1t about them? Like the E36 M3 not even having an S series engine? Or an S6 with G60,s? They arent even any good on an. S2, let alone the tank that a C4 chassis is?
      • Dec 2017
      • 5986
      Cheers for that. I will probably just overhaul these then
        • 4754
        Agree HP2's are very good, a version of it was Audi fitment to D2 S8 just a bigger rotor 323mm as apposed to S6 314mm, they do a very good job hauling down the 1750 kg's of the estate.
          • Dec 2017
          • 5986
          Cheers. I always fancied a Urs6 after meeting you and seeing yours at Audi International a few years back. As has been said already, a fantastic piece of machinery and well undervalued atm.
            Hello mate!
              • Dec 2017
              • 5986
              What shocks are recommended?
              Bilstien seem to have gone really expensive.
              • K Simmonds
                • Dec 2007
                • 7627
                Are there any Boge or Sachs options? Those would be my first choices.
                Though I have to confess I'm using two on the front of my Avant that simply say 'made in Germany' on them, they came with the car along with all new bump stops and gaiters etc. They look to be OE quality and the guy I purchased the car off said they were expensive, just hope their okay.
                1990 B3 2.0 80 quattro.
                1992 C4 2.8 Avant quattro
                1994 MTM RS2.
                1998 B5 TDI quattro Sport.
                2000 B5 TQS.
                  • Dec 2017
                  • 5986
                  Cheers Kit. I think Sachs do them. I will investigate
                    • Dec 2017
                    • 5986
                    Front struts got blasted. Wheel bearings came out with a bang.
                    After a final clean, two coats of my favourite primer.
                    I’m going to have to sort this oil cooler.
                      • Dec 2017
                      • 5986
                      My VAG mechanic friend lent me this as the ABY tool doesn’t fit AAN.
                      He said he uses it mainly on the 5 pot Audi diesel fitted in boats! Apparently quite a few about.
                      • Obli
                        • Jun 2022
                        • 43
                        Nice little project there Dave. Should keep you out of trouble
                        I noticed the Nothelle S2 in your sig. Very nice! My brother nearly bought a Nothelle Corrado VR6 years ago. He should have done!
                          • Dec 2017
                          • 5986
                          Yes, very rare now. Check out my 're build thread when you have a few hours to spare
                          • K Simmonds
                            • Dec 2007
                            • 7627
                            Nice bearing extractor, I really should invest in one of those. I get old outer races out by cleaning them, then running a heavy ring of weld around the inside with a MIG, that causes them to contract and they simply fall out. It's fairly quick but does mean dealing with very hot things, best done outside.
                            Do you know what's the purpose of those lugs/plates on the underside of the spring plate? My V6 models don't have them, but look the same otherwise.
                            1994 MTM RS2.
                            2000 B5 TQS.
                              • Dec 2017
                              • 5986
                              Nice trick with the welder. I must try that.
                              not sure about the lugs. I guess some kind of counter weight damping maybe
                              • K Simmonds
                                • Dec 2007
                                • 7627
                                Yeah, those lugs baffle me as it's more unsprung weight, I really can't see what purpose they serve but they must be there for a reason.
                                The welder trick works a treat even with a really stubborn outer race, Jim showed me how to do it and I couldn't believe how easily they drop out, just be ready for a red hot ring of metal rolling around, best done on the floor.
                                1994 MTM RS2.
                                2000 B5 TQS.
