Black Ur Project
  • Jaswan
    • Apr 2011
    • 774
    #286
    The calipers have came up brilliantly, how did you clean them up?
      • Dec 2017
      • 5999
      The carriers were done in my small sand blasting cabinet, the calipers were done using a wire wheel and then a final soak in Bilt Hamber rust remover.
      • Nuvo
        • Nov 2003
        • 3825
        #288
        Hi Dave, nice work with the rear calipers, are they Girling G36, i.e., 36mm diameter pistons? I can't quite make out the numbers on the caliper body.
          • Dec 2017
          • 5999
          Yes, 36mm early two part calipers.
          • B5NUT
            • Sep 2021
            • 1071
            Excellent work as usual Dave, the underside is looking really good. If the brake were seized it make you wonder how they did not notice this as they would have had to push the piston back to fit new pads, you don't need to apply much pressure to push a piston back but if it seized up that must have been hard work!
              • Dec 2017
              • 5999
              Baked brakes
              • Nuvo
                • Nov 2003
                • 3825
                #292
                Mmmm! "Braked" to perfection.
                  • Dec 2017
                  • 5999
                  New seals and pistons.
                  These abs kits were very reasonable and I was surprised when they came with stainless steel pistons.
                    • Dec 2017
                    • 5999
                    New caliper carrier bolts
                    These are 12.9 grade readily available from your bolt shop for a reasonable price. Don't be tricked into paying for Quattro specials.
                    Torqued up with some thread lock.
                    And caliper mounted
                      Lovely job!
                        • Dec 2017
                        • 5999
                        I finished off the brakes then onto the prop shaft.
                        I set about it with the wire wheel.
                        The joints all look good. Even the centre bearing carrier is good. I have a new one but I'm tempted to leave it.
                        All ready for some paint but it's gone very damp and humid so I will leave it until tomorrow.
                          • Dec 2017
                          • 5999
                          The propshaft was painted in zinc then epoxy.
                          Satin black as top coat when it's fully cured.
                          Onto front drive shafts.
                          Taken apart and wire wheel in action again.
                          A few other bits also done.
                          Front brake shields done in zinc and epoxy.
                          I've run out of zinc primer so a few parts will have to wait.
                          I'm off on holidays from tomorrow so have my first proper break from the car since Christmas.
                          I'm going somewhere interesting so will post some pics.
                          • Antsa
                            • Nov 2016
                            • 614
                            Nice progress as always. Have a great holiday Dave
                              • Dec 2017
                              • 5999
                              Falcon 9 launch this afternoon.
                              Also collected a fuel pipe for the Ur from a friendly forum member in the states. How good is that!
                              • Davi123
                                • Feb 2016
                                • 98
                                That’s an expensive fuel pipe Dave but assume you had other reasons to visit?
