20V CQ Tidy Up
    • 4754
    Eurika! Looking good there Alex but aren't those Inlet valves a little bit slim for longevity?
    • Bowie69
      • Nov 2013
      • 2675
      Aha, result
        • 4754
        Originally posted by Bowie69
        Aha, result
        • Wizard-of-OD
          • 926
          • Home: Syria Current: Canada
          #1594
          Originally posted by Error404
          -4 fitting installed for turbo oil supply.
          Careful here
          Did you empty out the thermostat portion?
          Oil goes from the engine into the thermostat portion , it is cooled and then returns to the thermostat portion where it is then filtered and goes into the engine.
          Blanking those 2 I am not sure how that would perform.
          If you want I could send you a 7A housing which does not have the oil cooler portion (perfect for the Mocal sandwhich plate) or use what I used which is off the 2.5 TDI A6
          it mounts the oil filter horizontally as opposed to vertically so creates some decent room for that oil return line.
          Part # : 046 115 417 (NOT 046115417B)
          http://allegro.pl/audi-a6-c4-2-5-tdi...227382074.html
          Issam N. Abed
          iABED Industries
          iABED Email | Facebook
          The build thread
            Hey Issam,
            Once you remove the stat internals then you basically bypass the cooler take-off section as there is a direct flow path to the filter
            I'd not seen the TDi part though, will take a look as it is a pretty busy area down there with the AC compressor etc, more space always helps
            • david1980
              • May 2014
              • 1025
              Any updates?
                Yeah I guess its probably time for an update. To be honest I've not had time to do too much but been working on the car this weekend so should have a good bit done by tomorrow.
                I fitted a 60-2 rear crank seal:
                New OEM tappets & cam chain
                I welded a -12AN oil drain on the rear of the head. This will link to the fitting I added to the sump with a -12 hardline, yet to be fabricated. Should take care of the oil surge in the head and improve drain-back to the sump, as well as crank case breathing.
                Sent my turbine housing an manifold off to be ceramic coated, full triple coat internal & external - I'm really impressed with the finish.
                Before hand I flashed over the mating flange on the Wagner manifold and it needed over 1mm milling off to give a flat mating face .
                Ported out the .82 housing a little, just to tidy it up where it was machined for the KKK manifold flange.
                Tapped the hotside flange for the EGT sensor:
                Tapped the compressor housing for a boost reference:
                Seemed a good time for a gratuitous shot of a shiny billet comp wheel:
                Next some work on the running gear.
                I fitted a new 27mm RS4 / RS6 master cylinder and B8 fluid reservoir. These use M12x1 fittings so I took the opportunity to revise some of the brake lines.
                The tandem servo actuation rod is shorter than the mono version, so I machined a longer CrMo clevis. Its a safety critical component so needs high end materials - I use ‎34CrNiMo6 / 4340 / EN24T
                And of course any time you can improve on OEM you should
                A crappy shot up under the dash showing my shiny new clevis at home
                Under the car, I fitted new custom stainless flexi-lines to the calipers. These plastic coils are a Porsche 996 part, tidying up the flexi & ABS line nicely.
                B5 RS4 rear hubs and refreshed uprights. The rear wishbones and subframe are looking a little tatty now, its been about 8 years now since they were looked at. I guess a 10 year cycle on refurbishment is acceptable
                This reminds me I still need to make a pair of brackets to retain the ABS cables.
                URS6 calipers, B5 RS4 rear carriers & grooved B5 RS4 rear discs. Wolfgang deserves the credit for the R&D on this bolt-on rear brake upgrade for the coupe - yes that's right - 100% bolt-on
                I skimmed & grooved the discs a while ago - surface rust shows how long they've been sitting about
                Up next, bigger front anchors. 996 GT3 4 pots originally supplied by Movit. I grooved & bored some 330 x 32 Brembo Mercedes discs & made some light-weight alloy carriers.
                You can order this kit from me if you fancy it - https://www.s2forum.com/forum/member...30x32-disc-kit
                • LukasR
                  • Nov 2014
                  • 166
                  Pictures are not shown...
                    Hmmm, works in Chrome & Safari
                    • AndyP
                      • 6049
                      Not working in Firefox or Chrome for me
                        Hmm, well they are hosted on the forum so I can only point the finger at Greg & Sonic
                        • LHD_Kid
                          • May 2006
                          • 3697
                          #1602
                          dont work on chrome on android.....
                            Well that's just odd as I can see them on every device in the house
                            • david1980
                              • May 2014
                              • 1025
                              I can see earlier pictures but today's one's do not work.
                              • Acki
                                • Mar 2014
                                • 302
                                "Invalid File Specified" it says.
