SWB Quattro Project
  • G60Rallye
    • Dec 2006
    • 1321
    SWB Quattro Project
    The car came from Edinburgh and has had an exciting life so far! It started life in Germany untill in was imported in the late 90's i think, so it is lhd. When it was brought into the country it was stolen and then recorverd after 9 months in a compound with a load of other stolen cars. Therefore it is on a Q plate.
    The car itself looks to be very solid on inital inspection (famous last words). It looks to have a couple of bits of rot on the boot floor but the floor pan as a whole looks realy nice!
    So here it is!!:
    Here it is in the garage it has a worried look in its eye, perhaps it has spied the grinder and welder?
  • Ian Simmonds
    • Jun 2005
    • 2858
    Looking foward to this one, it was screaming out for some attention...
    93 MTMS2 Avant
    • G60Rallye
      • Dec 2006
      • 1321
      Well I have been getting on with it over xmas. Got all the interior stripped out first:
      • G60Rallye
        • Dec 2006
        • 1321
        Then i moved onto the engine:
        • G60Rallye
          • Dec 2006
          • 1321
          Then I took a little more stuff out of the engine bay. This then moved into taking all the wiring out of the car. Whilst I was in there i decided to attack the sound deadening, untill the heat gun decided it would die after a couple of hours, so that put a stop to play there. So the windows came out of it bar the windscreen.
          • G60Rallye
            • Dec 2006
            • 1321
            I got the screen out first, but ended up cracking the bloody thing even with dad helping me. After I had got it out there was a nice hole in the passenger side bottom corner, some idiot had repaired it in the past by using filler to cover the hole!
            Then I moved onto the rear subframe, this all came to bits ok except for the nut holding the right rear upright on would not come off, managed to get it nearly off but the nut must have been cross threaded or the wrong nut so it just would not come fully off. This meant the grinder had to be called into action to spilt the nut off the threads to get it off. That done I got the subframe dropped off the car but left it under there as there is no where to put it in the garage at the moment.
            Then seeing as the grinder was out I decided to cut the inner pannel off the doors and then moved onto the rear 3/4's.
            • Ian Simmonds
              • Jun 2005
              • 2858
              Well, it's certainly come apart okay...
              Is the pair of eyes behind the fuel tank a LHD option?
              93 MTMS2 Avant
              • europeanme
                • Oct 2005
                • 3817
                blimey, been busy?.....
                whats the plan?.....engine, interior etc?!?!?.....
                • G60Rallye
                  • Dec 2006
                  • 1321
                  Sorry for so many posts but it will only let me post 10 images at once. I have spent a couple of days on it so far over xmas and its getting there, hoping to have the shell shortened by the end of january, then get started on the cage!
                  • shortsport
                    • Dec 2006
                    • 186
                    Fast work are you going for a full S1 kit?
                    • G60Rallye
                      • Dec 2006
                      • 1321
                      No S1 kit sadly. I will be going for the swb kit most likely in fibreglass so it will be easier and cheaper to repair. Full weld in roll cage to go into it with a pair of carbon seats, and not much else interior wise realy, trying to get it as light as possible.
                      I will be using an s2 engine with a gt35r so 550/600bhp on road fuel, 650+ on race fuel hopefully. What are your guys thoughts on using the coupe gearbox and rear diff to take that kind of power? Or will I be best using ur quattro stuff like the Keith Edwards car uses?
                      Hamish
                      • shortsport
                        • Dec 2006
                        • 186
                        I'm using the AAN and the 6 speed ur S4 box and the coupe Quattro rear diff,not sure how it will all work together i'll have to wait and see.
                        • volcano rs
                          • Jun 2005
                          • 2265
                          don't throw anything away you'll be surprised what's not available anymore
                          • G60Rallye
                            • Dec 2006
                            • 1321
                            I have thrown a good load of stuff away Jamil but its all parts that are not going to be going back on the car so its all good. What cant be bought can always be made my old man builds a lot of vintage cars so he is pretty handy in that respect.
                            • volcano rs
                              • Jun 2005
                              • 2265
                              i mean clips and small bits and bobs on the body work which are no longer available .i know from experience i threw so much away and realized afterwards.
