Project: RS2 ABY
MAF was used, i needed one at very short notice for when Dmitri was over so gladly took one off the shelf at VRS.
Shame it's only lasted a few k miles though.
I live in hope that i can find someone to just get the sensor, not the full MAF housing combined.S2Forum.com AdministratorComment
Now you have a spare you can get the exchange one, ask Jamo where he got his from, I'm sure it was only about £70?sigpic
1976 RD250E / 350LC cafe racerComment
Good that you've fixed it anyway, with no boost leaks the MAF was the most likely thing.Comment
Wow, you have all the luck in the world.
These RS4 MAF's fail extremely rarely. I have dozens of cars running about with them, many for more than two years and tens of thousands of miles with no issues.
I am very glad it's sorted though!!!
You can not buy only the element. I have been down this road and I failed.
The only elements you will find are chinese knockoffs. I am afraid you need to get the exchange MAF, and do the trick I described earlier (swap the sensor with your old used one!)
The RS4 exchange MAF's are MUCH cheaper than the S2 items, this is at least a good thing.Comment
MRC will tell you RS4 MAF's should be treated as serviceable items, you should replace them annually or bi-annually as whilst they don't fail don't measure correctly over time. I replace mine every service I'm due to change it end of year.
AndyP I got mine from GSF exchange item. I got a discount but about £70 sounds right I can check tomorrow.Comment
My MAF has been showing bang on for the past 2 years. Nothing has changed, go figure.
They do get wildly inaccurate if you contaminate them with oil though.Comment
You've noticed?
Likewise - they're far easier to get hold of anyway which is good!
The reaction to a knackered maf was far more extreme than I'd ever have thought, I mean the car was undriveable and even after running the car for only a few minutes whilst trying to diagnose all 5 plugs were black. The only other time I've felt the car that bad was after the first botched rebuild with low compression!
Cheers looks like the way to go then, and no problem now I have the wierd torx tool to just change the sensor!You can not buy only the element. I have been down this road and I failed.
Any idea when you're next over? I want to look at resolving the power "issues" and timing retardation this year in the form of changing the cams, stock pulley and Aquamist with a remap.
Thanks mateMRC will tell you RS4 MAF's should be treated as serviceable items, you should replace them annually or bi-annually as whilst they don't fail don't measure correctly over time. I replace mine every service I'm due to change it end of year.
Glad to hear it's sorted Andy, I was surprised the MAF caused it to run horrendously but it did look to be electrical related. I was sure it was soothing dodgy with your ignition, after you had a brief 'normal' moment when fiddling with the coil packs.
ECP sell the Bosch RS4 MAF, along with the other cheap alternates. You can use PAT30 for 30% off which brings it to £62 plus VAT, you'll have to pay the £24 surcharge but just swap the sensor + return it to get that back.AUDI - saving Dad's from minivans since 1994
I keep postponing it. I will put down some firm dates and back it up with buying non-refundable airline tickets as well. Just so much work here, booked for 2 weeks in advance all the time.Comment
Thanks for the research gents, i've sorted out getting a replacement with AndyP as i currently have his MAF unit... i'll be sending it back up to him with some funds to cover a replacement
Nothing like commitment to the cause
I need to discuss with Will first, but it would be good to have an idea of timescales to know when the work could take place.
I believe that sorting the cams out would go a long way to resolving the timing and power drops i currently have, and the aquamist kit being a real bang-for-buck upgrade to further enhance power output.S2Forum.com AdministratorComment
Ignition timing is fine I think, the problem is the engine does not breathe as well as it could.Comment
The RS2 exhaust cam seems rather pointless given the surge, so i was discussing with Will to get something to increase top-end.
Water meth would decrease intake temps and increase octane so timing can be advanced, and thus more power, right?
Intake... hmmm. Well it's running wagner IC with reverse inlet, and the head is fully ported, so is completely optimised at every point apart from the airbox which is an obvious restriction with the 4" inlet along with the RS4 MAF diameter and the turbo inlet.S2Forum.com AdministratorComment
