Project: RS2 ABY
  • AndyP
    • 6049
    Originally posted by Sonic
    IT'S ALIVE!!!
    Thanks to AndyP I received a brand new RS4 MAF on loan to test out last week.
    As my MAF housing is sealed into my RS2 airbox i was reluctant to remove it to just replace the entire MAF, so I embarked upon trying to just replace the sensor, thinking i could just remove it with my security torx heads in my socket set.
    It turns out it's not your standard security torx at all, and after being unable to find the correct type in Halfords realised the bolts are infact a T25 5-tip security torx, which appear to be ultra rare, but thanks to Amazon i had a set delivered this afternoon.
    I can confirm the MAF sensor PN is F 00C 2G2 047.
    Glad to have helped
    Was your MAF an original Bosch one or one from Ebay?
    • Sonic
      • Jul 2006
      • 5514
      #1742
      MAF was used, i needed one at very short notice for when Dmitri was over so gladly took one off the shelf at VRS.
      Shame it's only lasted a few k miles though.
      I live in hope that i can find someone to just get the sensor, not the full MAF housing combined.
      S2Forum.com Administrator
      • AndyP
        • 6049
        Now you have a spare you can get the exchange one, ask Jamo where he got his from, I'm sure it was only about £70?
          Good that you've fixed it anyway, with no boost leaks the MAF was the most likely thing.
          • prj
            • Mar 2010
            • 6308
            Wow, you have all the luck in the world.
            These RS4 MAF's fail extremely rarely. I have dozens of cars running about with them, many for more than two years and tens of thousands of miles with no issues.
            I am very glad it's sorted though!!!
            You can not buy only the element. I have been down this road and I failed.
            The only elements you will find are chinese knockoffs. I am afraid you need to get the exchange MAF, and do the trick I described earlier (swap the sensor with your old used one!)
            The RS4 exchange MAF's are MUCH cheaper than the S2 items, this is at least a good thing.
              MRC will tell you RS4 MAF's should be treated as serviceable items, you should replace them annually or bi-annually as whilst they don't fail don't measure correctly over time. I replace mine every service I'm due to change it end of year.
              AndyP I got mine from GSF exchange item. I got a discount but about £70 sounds right I can check tomorrow.
              • prj
                • Mar 2010
                • 6308
                My MAF has been showing bang on for the past 2 years. Nothing has changed, go figure.
                They do get wildly inaccurate if you contaminate them with oil though.
                • Sonic
                  • Jul 2006
                  • 5514
                  #1748
                  You've noticed?
                  Likewise - they're far easier to get hold of anyway which is good!
                  The reaction to a knackered maf was far more extreme than I'd ever have thought, I mean the car was undriveable and even after running the car for only a few minutes whilst trying to diagnose all 5 plugs were black. The only other time I've felt the car that bad was after the first botched rebuild with low compression!
                  Cheers looks like the way to go then, and no problem now I have the wierd torx tool to just change the sensor!
                  Any idea when you're next over? I want to look at resolving the power "issues" and timing retardation this year in the form of changing the cams, stock pulley and Aquamist with a remap.
                  Thanks mate
                    Ah that sounds plausible on the oil with the pcv setup
                      Confirmed it's an exchange item from GSF ( can't buy sensor only), GSF PN 187vg049.
                      Price is £70 plus vat retail £25 surcharge for non exchange
                      Cheaper if you can get trade price
                      • Ross
                        • Aug 2005
                        • 3399
                        Glad to hear it's sorted Andy, I was surprised the MAF caused it to run horrendously but it did look to be electrical related. I was sure it was soothing dodgy with your ignition, after you had a brief 'normal' moment when fiddling with the coil packs.
                        ECP sell the Bosch RS4 MAF, along with the other cheap alternates. You can use PAT30 for 30% off which brings it to £62 plus VAT, you'll have to pay the £24 surcharge but just swap the sensor + return it to get that back.
                        • prj
                          • Mar 2010
                          • 6308
                          I keep postponing it. I will put down some firm dates and back it up with buying non-refundable airline tickets as well. Just so much work here, booked for 2 weeks in advance all the time.
                          • Sonic
                            • Jul 2006
                            • 5514
                            #1753
                            Thanks for the research gents, i've sorted out getting a replacement with AndyP as i currently have his MAF unit... i'll be sending it back up to him with some funds to cover a replacement
                            Nothing like commitment to the cause
                            I need to discuss with Will first, but it would be good to have an idea of timescales to know when the work could take place.
                            I believe that sorting the cams out would go a long way to resolving the timing and power drops i currently have, and the aquamist kit being a real bang-for-buck upgrade to further enhance power output.
                            • prj
                              • Mar 2010
                              • 6308
                              Ignition timing is fine I think, the problem is the engine does not breathe as well as it could.
                              • Sonic
                                • Jul 2006
                                • 5514
                                #1755
                                The RS2 exhaust cam seems rather pointless given the surge, so i was discussing with Will to get something to increase top-end.
                                Water meth would decrease intake temps and increase octane so timing can be advanced, and thus more power, right?
                                Intake... hmmm. Well it's running wagner IC with reverse inlet, and the head is fully ported, so is completely optimised at every point apart from the airbox which is an obvious restriction with the 4" inlet along with the RS4 MAF diameter and the turbo inlet.
