Project: RS2 ABY
  • prj
    • Mar 2010
    • 6308
    Originally posted by Jamo
    You need to stop driving it while it is this rich it really bad for a new engine
    More correctly - driving is fine, flooring it, so it goes this rich is not good at all.
    • Sonic
      • Jul 2006
      • 5514
      #527
      It only changes from 14.7 when the car is cold or i give it serious throttle and come on boost, which as I'm coming to the end of running it in has not been the norm!
      Also after looking at Ross's graph his afr drops to 11.5 under boost (unless I've misread!), so I figure it can't be that uncommon.
      S2Forum.com Administrator
      • Ross
        • Aug 2005
        • 3399
        You need to borrow an air compressor and bring it down, or alternately I'll have to try and bring one up if I can find one. As has been said, stick to some 14.7 AFR cruising! Try and keep it >11, so pretty much off boost by the sound of it, at least you have gauges!
        • prj
          • Mar 2010
          • 6308
          Well, the AFR number you are seeing is a ratio.
          So 9:1 is a whole lot richer than you think.
          11.5 is perfectly fine, dipping below 11 is not, 9 is crazy rich and not good for the engine at all.
          So yes, driving it around is perfectly fine, just don't beat it around until the boost issue has been fixed
          • Sonic
            • Jul 2006
            • 5514
            #530
            I only see <11 when i use near-enough WOT, even at ~1 bar it's ~11.0 AFR, and i haven't been driving around with WOT.. infact first time was tonight and 9.6 is the lowest i've seen on this 1 occasion.
            Now that she's run-in i'll happily leave her on the driveway until i know i can get this sorted, especially if im going to cause damage driving it
            • Sonic
              • Jul 2006
              • 5514
              #531
              And there was me thinking this fore-play was only going to last for a week.
              • Sonic
                • Jul 2006
                • 5514
                #532
                If i get this thing will it do the trick? http://www.amazon.co.uk/dp/B001EX2UJ...1EX2UJG5294738
                • prj
                  • Mar 2010
                  • 6308
                  Actually even a hand pump would do the trick...
                  One guy pumping like crazy and other one spraying soapy water.
                  • Sonic
                    • Jul 2006
                    • 5514
                    #534
                    Foam-party at mine this weekend then, plenty of pumping and soapy water
                        I have some bungs if you dont have any nearby too
                        • AndyP
                          • 6049
                          Have you ever tried that? I tried it with a footpump when I first got my S2, talk about hard work Oh, and it didn't even work!
                          • s2_bo
                            • Oct 2005
                            • 6067
                            #538
                            I have tied a foot pump too but found that if you do have a leak there is no way you can build that much pressure, especially if the turbo seals leak a bit too..
                            The only way i got it to work was with a compressor. You could use a spare tyre if you have or make a female > female hose. Make sure you top it up first with a portable compressor to 50psi or so so that it has enough air in there to fill the pipes.
                            91 S2 coupé - RIP
                            98 S8 - Luxury barge
                            • prj
                              • Mar 2010
                              • 6308
                              I have, but if there is a big leak it does not work.
                              Does not sound like Sonic has a very big leak though, so that's why I think it might work, if you are pumping like a mofo
                              • Ross
                                • Aug 2005
                                • 3399
                                I have a 12V charger, although it's not as quick as a foot pump and furious pumper it doesn't ever let up, and may be enough. Either that or I borrow one as offered. Will speak to you about that offline...
