damn right. good luck mate, it'll be interesting to see what happens if you do fill it
3b s2 coupe resurrection
And more part collecting;
Some rearrangements required
Also need to sort a new cam cover vent as the rear one likes to spew under enthusiastic driving. Is there a minimum recommended size for this? (planning on a 90* bend coming of the top of the cover)Current-2004 Impreza PPP wagon
Sold ABY-stockComment
Got a new center bearing from Pete Reeve at Quattro corner.
Removed and split the prop last night
Easy way to remove the yoke (a wishbone bolt is the right thread if you need an longer bolt btw) ?Just unwind the bolt and the yoke is pushed off.
New and old (anybody notice anything wrong yet?)
Re greased the needle rollers in the buckets for the cruciform in the universal joint. Also re greased the cruciform center.
All done
Go to fit to the car, bot of a fitment issues, didn't bother comparing before as its meant to be a replacement. Stupid mistake I know.
So requires modding
Should fit, however pretty ****ed off as I bought a new center prop bearing for an s2 and was sent this. Phoned Pete and he said yeah they require modding, no mention of that when purchased.
However car should hopefully be good now.Current-2004 Impreza PPP wagon
All finished and fitted today, the prop cannot now be banged about by hand from under the car, however I am still getting some drivetrain shunt, wll need to pick up some gearbox mounts.
DIY reinforced rear diff mounts, filled the voids
Will do the same with a set of gearbox mounts and get them installed.Current-2004 Impreza PPP wagon
Replaced the rear diff side mounts and both gearbox mounts, the diff mounts looked pretty tired and the gearbox mounts were torn. Filled the new mounts before I fitted them so will see how they hold up.
Less slop now, however still getting an clunk from on/off throttle, sounds/feels like it comes from behind the seats. Anybody got any suggestions?
I have fitted new
center diff mount (powerflex)
side diff mounts
center prop bearing
gearbox mounts
360* snub mount
Car has alloy rr sub frame mounts
Could the front sub frame mounts be shot? I thought the car would handle like **** if they or other suspension components were shot, engine doesn't look like it is trying to climb out the bay.
Getting pretty frustrated with this drive train shunt now
Also got an issues with the dash/aux/blower controls illumination, everything has died simultaneously, clock/computer still work, centre switched still illuminate but no dash lights. I have changed clocks, and the relay behind the aux gauges, any other potential faults.Last edited by andy10v; 24 August 2010, 21:16.Current-2004 Impreza PPP wagon
I have not touched the engine mounts, had a quick look with handbrake on and letting clutch up and it didn't appear to jump.
How do you check them?Current-2004 Impreza PPP wagon
I've got loads of g/b and diff mounts laying around plus every nut/bolt to do a complete running gear setup for a 3b laying around.
One thing - the aan inlet manifold - have you got the fuel rail or water rail as your stock 3b one's won't work with the aan one.Comment
Nope, just grabbed the aan intake as it was for sale at the right price and I had the cash, I will collect the other bits over time, it will not be going on until I have the head off or similar, no real hurry.
Do you know if the aan fuel lines will mate up to the 3n hardlines?Current-2004 Impreza PPP wagon
£130 delivered for the pair from 034, just would rather spend £60 if they will be ok, guess we will see.Current-2004 Impreza PPP wagon
