Had another look at 'B71' sheets here for the ACE engine...
To remove the loom cleanly from the CEP it looks like all you need to unplug is the following
1 x L30 wire
87a and its associated fuse
The black 'B' plug
By removing the 'B' plug makes it easy for you to splice in the wires for B15, B15a and BS onto the AEB loom. Result will be really neat too.
I havent bottomed out on the reverse lights yet though... they might be part of ACE engine loom (the switch is certainly on the 5cyl looms) or they may be in another loom.
It appears the ACE engine uses generic Coupe loom to feed the starter solenoid signal down to the right location... so you can access it via a splice at CEP or the engine end of the loom as you like.
1 x L30 wire
The black 'B' plug
wahoo, this wiring malarkey is a piece of p155, lol not
lol.
