UrS4 2.2T Avant project
    That looks excellent Thomas
    • AndyP
      • 6049
      Originally posted by Thuppu
      Ooh, sorry. Totally forgot. I will do it tomorrow.
      Me too!
      • Thuppu
        • 4115
        Yes Andy, sorry. Have quite a lot of things going on atm... easy to forget something.
        • Thuppu
          • 4115
          Tight fit, but it does fit. A small aligment job has to be done for the pipings... The dipstick pipe needed to be bend a little to fit. Need to do a bracket for it.
          • kenax
            • Mar 2010
            • 85
            Originally posted by quattro-nick
            do you use a origional throttle off a AAN engine?
            what is your goal about hp?
            Why not use stock throttle body? It should be good for around 1000hp based purely on the throttle body WOT flow area..
            I have taken the "small opening blocker" off the flap though..
            • Thuppu
              • 4115
              Still some small things to do, but I belive soon it's time to test.
                Beast
                • Wrath
                  • Jan 2011
                  • 779
                  Time for a new water tank I guess
                  Otherwise everything looks awesome as stated before... wish I could weld like that mmm the things I would make
                  1995 Audi S6 - AAN (~350hp)
                  2008 BMW 530xd (235hp)
                  2011 KTM 990 SMR - custom tuned (120whp)
                  • zafra
                    • Jun 2013
                    • 320
                    • Country: Spain
                    #984
                    where is the radiator?
                    Step 1: setup. <==
                    Step 2: potentiation.
                    Step 3: enjoy.
                    • kenax
                      • Mar 2010
                      • 85
                      I bought the coolant tank from Alvadi.ee, it was dirt cheap, like 20e or so
                      • Wrath
                        • Jan 2011
                        • 779
                        So did I
                        • Thuppu
                          • 4115
                          Whats wrong with the expansion tank? Well, it's on the "to do" list. Next time I'll order a bigger amount of parts... http://spareto.com/products/dba001tt...n-tank-coolant
                          The radiator is in the stock place. It have been moved few cm backwards though.
                          • andy10v
                            • 5996
                            Sweet!
                            Is the TB braced?
                            Sold ABY-stock
                            • Thuppu
                              • 4115
                              Andy, no it isn't, not yet though. Maybe it's not needing any bracing, the v-band seems to hold quite stiff.
                              • Thuppu
                                • 4115
                                50mm BOV found the place where it will sit tight. Quite slow progress here, but havn't have much time in the garage...
                                Also got a nice little packet from FIN-Turbo today. Compared to the stock HX40S, comp + 5.5mm(billet) and ex +3.0mm.
